5915 Discussions
Arria 10 10AS032E3F29I2SG MAC IP 时序违例
Jekyll
在使用Arria 10 10AS032E3F29I2SG的时候出现以下路径时序建立时间为负值,查看路径发现是1G/10G mac ip 里的路径,该路径的工作频率是312.5Mhz,时序违例如下附件,请问:
ZiYing_Intel
Can you share your .qar here? So that I can try debug the issue from my side.
zying
Jekyll
I can only show the timing report and the Mac ip interface signal connection code as follows
ZiYing_Intel
Is there any update from your side?
zying
ZiYing_Intel
I have a discussion about this issue with my team. In your case, the negative value of the timing is considered as abnormal. The failure seem in the IP, you need to check whether the IP is closed if standalone. If the failure seem inside the IP, you might check back your design or maybe your design is having some issue.
zying
ZiYing_Intel
zying
ZiYing_Intel
Since no hear any feedback from you, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
ZiYing_Intel
zying
ZiYing_Intel
zying
