I've got an Arria 10 GX FPGA Development Board (DK-DEV-10AX115S-A) and am trying to convert a .sof file to a .flash file for use with the board. I'm using Quartus Prime Standard 23.1.
I'm referring to these instructions to attempt to do that:
Step 2 instructs to navigate to the .sof file while in the Nios II Command Shell. How is this done?
Without navigating, I've entered the Step 2 text but received this message when completed:
No .flash file appears to have been created.
How can I create a .flash file?
Any help would be appreciated - thanks.
Hi BigSid,
Can try to refer to the sof2flash function in the document below:
https://cdrdv2-public.intel.com/666773/ug_nios2_flash_programmer-683118-666773.pdf
Regads,
Aik Eu
Hi Aik Eu,
Thanks for the document. I 've read it but still don't understand the problem.
Would it be easier to generate the .flash file using the Nios II Flash Programmer GUI? I've tried to start the GUI from the Nios II Command Shell by following the instructions shown on page 9 of your document but get this:
Any guidance would be appreciated - thanks.
Hi BigSid,
You will need to source the Nios2_coomand_shell in your terminal then only can run the sof2flash cmd.
Aik Eu
Run the nios2_command_shell in the correct directory path in your terminal.
Then only run the sof2flash in your nios2_command_shell terminal in the correct directory path where your sof file allocated.
Hi Aik Eu,
I've opened the Nios II Command Shell from its installed folder. Do I also need to copy and paste my design's .sof file into that same folder to create a .flash file using the command shell? Please list the needed steps.
Hi BigSid,
You do not need to copy and paste the .sof file into the same folder.
As long as Nios II command shell is enabled in your terminal, you will just required to go to the directory path with your project .sof file and execute sof2flash.
Aik Eu
Hi Aik Eu,
Sorry, but I don't understand. The Nios II command shell is opened and I've entered the command to create a .flash file:
The error "sof2flash: command not found" is given.
How do I go to the directory path with my project .sof file and execute sof2flash? I don't know what that means. Do I do that in the command shell? If so, how? How do I execute sof2flash?
I appreciate your patience here but I just got the development kit and have never needed to create a .flash file before.
Hi BigSid,
I think there is some missing component in your environment setup which leads to the command not found. Can refer to the link below:
https://www.macnica.co.jp/en/business/semiconductor/support/faqs/intel/134526/
Aik Eu
Hi Aik Eu,
I've added the .exe extension and now get this:
I'm listing a valid .sof file for this design. Does it need to be in a certain folder/location for this sof2flash.exe command to work? If so, where?
Are you in the directory where the .sof file is located? If not, you have to include the path to it in --input= or cd to where it is located before issuing the command.
Hi BigSid,
Ya same according to SStrell comment, you will need to be in the directory of where your .sof file has been generated then only run the sof2flash command.
Aik Eu
Hi BigSid,
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Aik Eu
Hi Aik Eu,
I've put the .sof file into the same folder as the Nios II Command Shell.bat file.
Now I attempt to run the sof2flash.exe command and get this:
Any idea what's happening now and how to proceed?
