Hi there! I’ve just purchased Cyclone III Video Dev Kit from Bitec and want a bit of guidance from the experts ;) This kit includes a Cyclone III EP3C120F780 FPGA.
My experience with Altera FPGA’s and software is kind of low, so I have some questions for you. 1. Is there more design examples available online? The ones with the kit are “my_first_fpga”, “niosII_standard”, “pfl”, “power_demo” and “quartos_pinouts”. I first of all want to make a simple code that prints something on the LCD display (graphical or character). The tutorials with the kit/sw are rather simple … 2. With limited knowledge in FPGA’s I need some “pointers” to quickly gaining knowledge from Altera’s literature. What are the basic topics for a newbie like me? ;) 3. What kind of programming languages is most efficient VHDL (Quartus II) or C (NIOS II IDE) and does it matter what I use? I have some knowledge in both of the programming languages so that’s not the main challenge. 4. My ultimate goal is to develop a video-over-ethernet (real-time speed) using the Bitec HSMC Quad Video daughter card to capture from an analog camera (NTSC) and stream this over ethernet. Will a “soft implementation” using the NIOS II IP (and other necessary IP’s) be fast enough, what do you think? Well that’s it :) I’m very excited about this and hope there is someone out there that will give me some guidance in the right direction with links etc. Thank you all in advanceLink Copied
--- Quote Start --- <snip> 1. Is there more design examples available online? The ones with the kit are “my_first_fpga”, “niosII_standard”, “pfl”, “power_demo” and “quartos_pinouts”. I first of all want to make a simple code that prints something on the LCD display (graphical or character). The tutorials with the kit/sw are rather simple … <snip> 4. My ultimate goal is to develop a video-over-ethernet (real-time speed) using the Bitec HSMC Quad Video daughter card to capture from an analog camera (NTSC) and stream this over ethernet. Will a “soft implementation” using the NIOS II IP (and other necessary IP’s) be fast enough, what do you think? --- Quote End --- Check out the 'vip_example_design_3c120_v80_revA' that demonstrates the Video IP suite; it's pretty good, once you figure out some of the 'qwerks'. It is made for the BiTec kit combo. Mike PS: I wish I could afford that kit.
Hi
Bitec have just uploaded a h.264 encoder demonstration which streams video from a DVI port to GiGe.- Mark as New
--- Quote Start --- Check out the 'vip_example_design_3c120_v80_revA' that demonstrates the Video IP suite; it's pretty good, once you figure out some of the 'qwerks'. It is made for the BiTec kit combo. Mike PS: I wish I could afford that kit. --- Quote End --- Thanks! I will give this design example a try! :) What kind of compression does it use?
--- Quote Start --- Hi Bitec have just uploaded a h.264 encoder demonstration which streams video from a DVI port to GiGe. --- Quote End --- I will take a look at this :) My first approach will be streaming video without any compression at all. I hope this kit will handle it :) Thanks for answering! :)
Another question: I've just requested the Video IP Reference Design from Altera, but seems like it takes some time ... anyone know for how long I have to wait for this reference design?
It's too big to up load; or it would be here.
--- Quote Start --- It's too big to up load; or it would be here. --- Quote End --- OK! Just sent you a PM mikehsr ...
Finally got the 'Video Over IP Reference Design' and trying to port it to Cyclone III Video Kit. I have added a 'Bitec QVideo In' module from the 'Quad Video Input'-example and successfully generated files from the SoPC-builder, but I need some help with the pin-assignment. Can this be done with a tcl-script? Or must I do this manually in the schematic diagram and the pin planner?
--- Quote Start --- Finally got the 'Video Over IP Reference Design' and trying to port it to Cyclone III Video Kit. I have added a 'Bitec QVideo In' module from the 'Quad Video Input'-example and successfully generated files from the SoPC-builder, but I need some help with the pin-assignment. Can this be done with a tcl-script? Or must I do this manually in the schematic diagram and the pin planner? --- Quote End --- All three are methods; if your more comfortable with tcl, use it. Mike
Okey, thanks Mike I'm done experimenting with different reference designs and a bit annoyed when fiddling about with the SOPC-builder trying to make a system from scratch. I can't seem to find the right Avalon-ST interface to use with the Triple Speed Ethernet component. This sopc-project also includes a NiosII processor and using the Clocked Video Input that I want to send raw-RGB to the TSE. Some suggestions? I know that it's needed with some "glue-coding" afterwards but I just wonder whats possible to do with the SOPC.
I'm using the SGDMA-component to connect to the TSE and that works for now ;)
