5925 Discussions
How to set the most significant bit in an STD_LOGIC_VECTOR(data_width downto 0) to 1 without changing the other bits
rgodw
I'm trying to set the first bit in a logic vector to 1 so that the number is signed as a negative
AnandRaj_S_Intel
Hi Rory,
Yes, you can change a single bit in a vector without impacting other bits.
Example:
Data : in STD_LOGIC_VECTOR (15 downto 0);
x: out STD_LOGIC_VECTOR (15 downto 0);
signal signBit : std_logic:='1';
signal sig : std_logic_vector(31 downto 0);
sig(31)<=data(15);
signBit <= Data(15);
x(15)<='1';
Anand
rgodw
thank you so much that's really helped.šŸ˜
