6217 Discussions
Quartus do not see Stratix® 10 MX FPGA as a PCIe* card
markm_1915
I have inserted Stratix® 10 MX FPGA into a PCIe* slot, and installed Quartus, but Quartus doesn't see the hardware/FPGA. If there are some problems with PCIe, or I have to install/activate smth?
markm_1915
 I have installed Stratix® 10 MX FPGA into a PCIe* slot, but Windows Device Manager doesn't see it. What can be a problem?
Still, when the desktop and  board powers up, the blue power LED illuminates and the board is ready for use.
sstrell
You have to plug in the separate brick power supply.  It needs more than just the slot power.
markm_1915
Thanks! I tried this but doesn't help. I notice that BIOS doesn't see Stratix, and map the PCI slot as empty.
Farabi
"We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Thank you for your understanding."
