Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
5283 Discussions
system-console, close_service not working?
covfefe
I am trying to close_service & claim_service (to handle disconnected devices).
Unfortunately I am unable to make it work.
  1. How can I close_service pathA, then claim_service pathA ?
  2. Or, alternatively close all service paths, to keep the service console, but start fresh?
close_service master {%s}; claim_service master {%s} m
Response:
CLIENT (sock2532): close_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master}; claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m
SERVER (sock2532): Invalid command from the client
ErrorMsg : Could not claim service at /devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master: Channel is opened
    while executing
"claim_service {master} {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} {m}"
ErrorCode: NONE
ErrorInfo:
    while executing
    while executing
"claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m"
    ("eval" body line 1)
sstrell
close_service has to point to the claim path, not the service path (in your case, the master service path).
claim_service will point to the master service path.
covfefe
Isn't this what I am doing?
sstrell
No, it looks like you are using the master service path for both close_service and claim_service.  A claim path is usually created like this in a script after you've created the service path (mpath in this case):
set claim_path [claim_service master $mpath {} {}]
So then close_service can simply be:
close_service master $claim_path
covfefe
Thank you. Right now, if I try to
and the channel is open, I get an error message. How can I bypass this issue, without knowing the claim path? I assume I first need to close the channel, then do claim_service.
An attempt at
is_service_open master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master}
does not work, and returns 0 regardless.
An attempt at
get_claimed_services master;
returns no values.
set claim_path [claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} {} {}]
 crashes by saying could not claim service, channel is open
sstrell
So you've done claim_service previously but you don't know what the claim path was?
What if you just write the whole thing out:
close_service master [claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m]
covfefe
This does not work.
As the previous message says, this command crashes
CLIENT (sock2472): claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m
SERVER (sock2472): Invalid command from the client
so the following command as well
CLIENT (sock2472): close_service master [claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m]
Yes, claim_path is unknown (application reboot)
ShengN_Intel
Or may be try to get service path first like below:
set m_path [lindex [get_service_paths master] 0 ]
set c_path [claim_service master $m_path ""]
close_service master $c_path
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
ShengN_Intel
Any further update or concern? Does your problem resolved?
ShengN_Intel
Since there are no further updates or concerns for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
covfefe
Thank you, the following successfully closes the service path:
set m_path [lindex [get_service_paths master] 0 ];
set c_path [claim_service master $m_path ""];
close_service master $c_path;
Now, to be able to re-claim an existing path, I first need to be able to check if it is closed. However, this command returns 0 regardless of the status (open or closed).
 Which then errors on the next command to claim it
CLIENT (sock2256): claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m
SERVER (sock2256): Invalid command from the client
Is it possible "close_service master" does not really close it?
ShengN_Intel
After close_service, you have to get_service again in order to claim_service. claim_service can't be done straight away after closing service.
Sheng
