Intel i3-8100 having fps drops
TimTheBeastNL
my intel i3-8100 is having massive fps drops and high CPU usage when I'm gaming. I also have a GPU so its not only my  CPU I use for gaming. does anyone have a fix for the fps drops?
Steven_Intel
Hello TimTheBeastNL,
In order to better assist you, please provide the following information:
  • Which games are having the issue?
  • Was there any driver/OS update before the issue started?
  • How are you measuring the drop in FPS?
Steven G.
Steven_Intel
Steven G.
TimTheBeastNL
hi, I have an issue with Minecraft, Valorant, and Fortnite. I think it was since a driver update. And I know the FPS drops because they go to 0 and my game is frozen on 1 frame for more than 3 seconds. I also have high input delay And when I'm not doing anything i have high CPU usage.
Lockit
If you really are at a loss and your system is giving you that many issues, my go to is always a system refresh. Just makesure you have everything you want saved on an external device before a system reset. Ive spent countless hours/days dealing with glitchy computers and if all they are being used for is gaming and browsing, a fresh install every now and again never fails to bring the system back to new and snappy!
Steven_Intel
I appreciate the information.
I would like to investigate further about this, please provide the following information:
  • If you roll back to the previous driver version, does the issue disappear?
  • Do you have the latest updates/patches of these games installed?
Download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
ZeeshanIlyas
Your PC games are powered by it and your graphics card. This Intel CPU has four cores and four threads, and its clock speed is 3.6 GHz. PCGameBenchmark rates processors by measuring how many of the top 1,000 PC games they can run. This Intel CPU can run 849 out of the top 1000 games, giving it an 84% rating.
