hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
21969 Discussions
Arc B580无法玩诛仙世界,功耗显示错误
RuaL
型号:Intel Arc B580 Photon W 12G
玩诛仙世界时,显卡使用率始终都没有超过70%,并且会出现闪退情况,可能是游戏使用了虚幻五引擎。
我在Intel显卡驱动里看到的功耗与在GPU-Z里对比,发现Intel显卡驱动里的功耗为核心功耗,显存以及外围配件并未包括在内。
蓝戟显卡卖点为超低功耗,我的屏幕是1080p@165hz,在这个分辨率和刷新率的情况下,显卡整卡的待机功耗为40w左右,核心功耗20w左右,显存功耗7w左右。
希望能加快对虚幻五引擎的适配,现在使用虚幻五引擎的游戏Intel显卡几乎都是卡的没法玩。
RuaL
I'm sorry, I didn't describe it in English, this is the result after I translated the content with software: Model: Intel Arc580 Photon W 12G When playing the world of Zhu Xian, the GPU usage never exceeded 70%, and there were cases of, which may be due to the game using the Unreal Engine 5. The power consumption I saw in the Intel GPU driver compared to that in GPU-Z, I that the power consumption in the Intel GPU driver is the core power consumption, and the memory and peripheral accessories are not included. The selling point of the Blue Sword GPU ultra-low power consumption. My screen is 1080p@165hz. In this resolution and refresh rate, the standby power consumption of the GPU card is about 40w, the core power consumption is about 20w, and the memory power consumption is about 7w. I hope speed up the adaptation of the Unreal Engine 5. Now, games using the Unreal Engine 5 are almost unplayable with Intel GPUs
Ernesto_C_Intel1
Hi @RuaL,
Thank you for posting in Intel Customer Support.
请注意,我只能用英语为您提供支持。感谢您为翻译您的初始消息所做的努力。我将继续用英语为您提供支持。请注意,如果您用中文回复,我将使用网络翻译工具来翻译您的信息,因此,可能会有一些不准确的翻译。
In order to better understand your situation, I would like to clarify the following:
1. I'd like to know the exact symptoms that you are experiencing while playing games such as Zhu Xian? Do you experience Low FPS issues, stuttering, screen tearing or others? Kindly elaborate.
2. May I know the specific games that you have experienced to have issues with the Intel B580 graphics cards?
3. Can you share the settings that you've used for the games that you've mentioned?
4. What troubleshooting steps have you done to address the issues you've mentioned on the affected games?
Ernesto C.
Earl_Intel
Hi RuaL,
Earl E.
Earl_Intel
Hi RuaL,
Earl E.
