I use A750 with latest driver 31.0.101.5522 WHQL.
Blackmagic Fusion 18.6.6 Magic Mask keeps crashing.
When I use the Magic Mask tool in DaVinci Resolve Fusion tab it works great.
Hello Plyta,
For us to check your concern, please provide the following information:
- Were you able to use the app without any issues before?
- Can you provide the steps to replicate the issue? We will try it on our end.
- Please provide a System Support Utility (SSU) log of your system. This will allow us to check your system details and configuration.
Awaiting your reply.
Caguicla C.
SSU log
Hello.
I am attaching a file..
Hello Plyta,
Thank you for your reply.
Before we further investigate this issue, can you share if you were able to use the app without any issues before? Is it also possible for you to provide the steps to replicate the issue? We will try it on our end.
Caguicla C.
Hello.
Thanks for the reply.
My system used to work with NVIDIA RTX without problems.
After installing ARC A770 just crash.
I will reiterate that there are no such problems with DaVinci Resolve Fusion.
Hello Drasutis,
Thank you for providing the requested information. We will investigate the issue internally and give you an update as soon as possible.
Caguicla C.
Hello Drasutis,
Thanks for your patience.
The latest Graphics Driver, version 31.0.101.5534, for Intel® Arc™ A750 Graphics is now available. Could you please install this driver and see if it resolves the issue before we proceed with further investigation?
Additionally, could you inform us of the version of the application you are currently utilizing?
Caguicla C.
Hello.
I uninstalled an old drver with DDU. I installed intel® graphics driver 31.0.101.5534.
Fusion Studio 18.6.6 build4 Magic Mask, Depth Map ( AI tools): Crash.
Fusion Studio 19.0 beta build29 Magic Mask, Depth Map ( AI tools): Crash.
Davinci Resolve Studio 19.0B build 33: no problems.
Hi Plyta,
Thank you for updating the driver.
We will include the results of this suggestion on our investigation of the case.
We will get back to you once we have updates.
Alfred S
