20642 Discussions
OpenGL - Intel UHD Graphics - Hit test with glRenderMode(GL_SELECT) doesn't work or crashes
WernerSlabon
Hello Intel,
I'm developing a software using OpenGL to display 3D-maps (e.g. distribution maps). The code is used for about 15-20yrs. In all the time Intel GPUs/drivers were source of problems (crashes) while AMD and Nvidea were always stable - but it wasn't that worse and updates seemed to help - or the customers get used of "our" bad software.
Nevertheless, after having less problems in the past years, we receive many crash reports pointing to issues with the Intel UHD Graphics driver. The crashes all happen when our software performs a hit test using gluPickMatrix(), glRenderMode (GL_SELECT) and rendering the prepared glLists to select a data point in the 3D map.
After I got a notebook (HP 450 G9) for a couple of days, I was able to reproduce the same crash sporadically. More than this, I also recognized that the hit test seems to return "random" results in the select buffer! The returned selection returns completly different results even I move the mouse cursor only a couple of pixels.
I can provide several full memory dumps of the crashes (they are about 200MB each). I can also provide our application with test data (and probably a video, if I ask a customer using a notebook with Intel GPU). But with a ticket, I can only send files with up to 71 MB ...
Here is a screenshot of one crash dump showing:
You can see the driver version, the disassembly (purple marked) of the line causing the access violation (0xc0000005) and the position in the stack. The blue marked lines are the calls from our code. The bottom right inspect window shows the register values (rax = 0x1 causes the crash). The rax value was taken from the address in rcx. The inspect shows the values around the current rcx address. Obviously the value at rcx (0x00000001) looks as if it doesn't belong there.
Not in the screen shot: If I watch at the other addresses (e.g. 0x0000000014bd1e28) it looks like these are pointing to a vertex buffer. I can see reasonable x-y-z float values!
Thanks for a reply to investigate the issue further!
Labels (2)
DeividA_Intel
Hello WernerSlabon,
Thank you for posting on the Intel® communities. I understand that Intel graphics are giving you a hard time with your software.
Before I move forward, I would like to confirm these 2 details:
1. Are you working for a company? If so, what is the name?
2. Is this project related to the company you work for? Or, is it personal?
Deivid A.
WernerSlabon
I‘m a freelancer working since >25yrs for Bosch Engineering / Bosch Motorsport.
The software I‘m working on is used in several motorsport series worldwide.
DeividA_Intel
Hello WernerSlabon,
Thanks for your confirmation. I will send you an e-mail to the e-mail address associated with your community profile. Please reply to the email in order to provide us with the report and information needed to avoid exposing sensitive information in the communities.
Deivid A.
DeividA_Intel
Hello WernerSlabon,
Thank you for the information provided
I will proceed to check the issue internally and post back soon with more details. I have received and downloaded the information from the file you sent, you can proceed to disable the link.
Deivid A.
DeividA_Intel
Hello WernerSlabon,
I will send you an e-mail to the e-mail address associated with your community profile to collect and confirm some information needed for the investigation. I would appreciate it if you reply to that email with the details requested.
Deivid A.
WernerSlabon
Is there any progress on this issue?
We receive many crashes per week from our customers using Intel-based hardware.
Or is it Intel strategy to ait silently until customers give up?
Tom_Wolfe
I'm seeing the exact same issue in our application (20 yr old GIS mapping application). Hit test results seem random and the app sporadically crashes in the Intel GL driver. We use a mix of GL 1.x, 2.x and 3.x calls, but revert back to 2.x rendering for our selection/pick handling. Performing the same operation using nVidia, AMD or Mesa GL drivers works without a problem.
PC is a Dell Precision 5550 with Intel UHD Graphics (build 31.0.101.2127).
