21620 Discussions
Output display resolution limited to 1920X1080 via HDMI
MayankSharma
I recently purchased Dell Vostro 3520 (i5 -1235U) with iRIS xe graphics card. While connecting the laptop to Lenovo Thinkvision P32p-30 Monitor which supports a maximum of 3840x2160 resolution. However, my laptop is restricting the resolution to 1920x1080 (same as the laptop screen) on the secondary monitor as well.
I was earlier using Dell Lattitude 5490 with intel UHD graphics and that laptop allows monitor to display higher resolution ( All other setting remain same except the graphics card change).
Please help in resolving the issue.
Mayank
MUC
Valued Contributor III
Dell Vostro 3520 Setup and Specifications
Unfortunately, Dell has cut back on this HDMI port. It is limited to 1080p @ 60 Hz.
If your Dell device is equipped with an USB Type-C port [5], please connect to the DisplayPort connector of the monitor using one of these cables:
