Descargue el Juego Juego Off The Grid y tiene un rendimiento FATAL si alguna persona tiene una forma de arreglarlo lo agradezco tengo una Arc A750LE
Hello Jose13,
Thank you for your response and for sharing those details. I understand how frustrating it is to deal with low FPS.
To help pinpoint the issue, kindly confirm the following:
- Could you share the in game settings you're currently using?
- Have you performed other troubleshooting steps?
- Is Re-Bar enabled?
- Do you experience similar performance issues in other games?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
We look forward to your response!
Robbie R.
Hello Jose13,
Thank you for reaching out, I understand how frustrating it can be to experience performance issues, especially with a new game.
To further identify what might be causing the issue, please provide more details:
- Did you make recent changes to your system?
- Was this issue re-occurring or is this a new issue?
Robbie R.
El mal Rendimiento en solo en ese juego es prácticamente injugable voy a 30-40 fps solo se puede jugar de firma decente con tsr pero se ve fatal no tiene ni xess
Hello Jose13,
Robbie R.
Hello Jose13,
Robbie R.
tengo casi el mismo problema y placa de video, a mi no me deja ejecutar red dead redemtion 2, me pide un controlador de pantalla que no encuentro es el: 27.20.100.8280.
Creo que tengo los mismos que tu, tengo una intel arc a750 y un intel i9 generacion 12, el problema que ya tengo es de un controlador que no encuentro
Hello Jose13,
Thank you for your response! Please answer my previous questions:
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows* . Please send us the generated SSU.txt file.
Robbie R.
Hello Jose13,
Robbie R.
Hello Jose13,
Thank you for the additional information and for answering my questions.
Please answer the additional questions:
- Have you observed any specific scenarios in the game where performance worsens?
- What is your game settings?
- What is your power plan?
- Have you encountered this issue using older drivers?
- Have you noticed this issue with other games?
Robbie R.
Hello Jose13,
Robbie R.
Power plan is High performance
I updated the drivers and I have the same problem and I already said that at the moment I don't find this error in other games
