I used cmake to generate SLNS, adding the compile command /Qmsse3 /Qfreestanding.
Version:2.26.4
Output:
3>lld-link: : error : undefined symbol: __declspec(dllimport) ldexp
3>>>> referenced by SDL2.dir\Release\SDL.obj:(ldexpf)
3>>>> referenced by SDL2.dir\Release\SDL_assert.obj
3>>>> referenced by SDL2.dir\Release\SDL_dataqueue.obj
Thanks for posting in Intel communities.
Could you please provide us with the following details to investigate the issue more from our end?
1. oneAPI version you are using.
2. Hardware details.
4. CMake version.
3. OS details and compiler version.
4. And also please provide us with the sample reproducer and steps to reproduce the issue.
Thanks & Regards,
Vankudothu Vaishnavi.
2023.0.0.25839
4. CMake version.
3.26.0
Windows11 22621.1413
download sdl2 code,
https://github.com/libsdl-org/SDL/releases/tag/release-2.26.4
used cmake to generate SLN, Open sln and set to use the intel compiler.
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
