Intel® C++ Compiler
7932 Discussions
icx compilation problem with ipo and inline assembly
Jaka_Bac
icx has problems when building FFMpeg with IPO enabled. The problem happens when compiling this file
https://github.com/FFmpeg/FFmpeg/blob/96d2a40b9ee0ddd1844b82c23a074804c316caa5/libavcodec/x86/mlpdsp_init.c
The problem is that this uses some inline ASM labels in the C code. Apparently with IPO disabled this is not an issue possibly since the machine code is generated much earlier. With IPO enabled the labels become undefined symbols at link time.
I have created a toy C file that reproduces the issue unrelated to FFMpeg:
#include <stdio.h>
extern char label1;
extern char label2;
extern char label3;
static const void* const jmptable[3] = { &label1, &label2,
                                          &label3 };
static int asmtest(int a) {
    int retval;
    const void* jump = jmptable[a];
    __asm__ volatile(
        "jmp *%1\n\t"
        "label1: \n\t"
        "mov $1,%0 \n\t"
        "jmp label4 \n\t"
        "label2: \n\t"
        "mov $2,%0 \n\t"
        "jmp label4 \n\t"
        "label3: \n\t"
        "mov $3,%0 \n\t"
        "label4:"
        : "=r" (retval)
        : "r" (jump)
    return retval;
int main()
    printf("%d\n", asmtest(2));
When building this with IPO enabled you get:
lld-link: error: undefined symbol: label3
>>> referenced by ipotest.c
When building with IPO disabled the sample compiles fine.
Since I was testing on Windows, I also tried to reproduce the issue on Linux by using Godbolt Compiler explorer.
There the sample links fine even with -ipo flag
I suspect that this is actually an issue somewhere in LLVM's LLD and link time code generation.
https://godbolt.org/#z:OYLghAFBqd5QCxAYwPYBMCmBRdBLAF1QCcAaPECAMzwBtMA7AQwFtMQByARg9KtQYEAysib0QXACx8BBAKoBnTAAUAHpwAMvAFYgATKVpMGoZAFI9AIQuXSS%2BsgJ4BlRugDCqWgFcWDfaRuADJ4DJgAcr4ARpjEIADM8aQADqgKhM4Mnj5%2BEilpGQIhYZEsMXFcdpgOTgJCBEzEBNm%2B/gb2mI6Z9Y0ExRHRsQlJCg1NLbmVo739peUSAJR2qN7EyOwcFvGhyD5YANRm8e6j%2BKgAdAhH2GYaAIK3d5iqBLEM%2B8gIjftGMbRcR2s92e...
SeshaP_Intel
Thank you for your patience. The issue here is that the Windows/COFF version of lld tries to determine if there are undefined symbols before compiling the bitcode files. The compiler cannot parse the ASM code. It looks like a black box to it, So, it will not recognize labels that are defined in the asm code. If there are bitcode files and there is an unresolved reference, Windows lld will exit early to save the time of compiling the bitcode files. The Linux/ELF version of lld does not do this. It only reports the unresolved symbols after all of the bitcode files have been compiled.
You can bypass this early exit check in Windows/COFF by adding "/link /force:unresolved" to the linking command. Please refer to the screenshot below for more details.
Could you please confirm whether we can close this thread from our end?
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We were able to reproduce your issue. We are working on it internally.
We will get back to you soon.
Thanks and Regards,
SeshaP_Intel
Thanks and Regards,
Jaka_Bac
Hi Sesha,
Thank you for the detailed analysis and the provided workaround
Jaka
SeshaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
