Intel® C++ Compiler
7932 Discussions
icx error: wrong code at -O2/3 since `x86-64 icx-2023.2.0`
Junwei_Zeng
I compiled the following code with icx at -O2/3, and it produces the wrong code. The correct output result should be 1, but 0 was output under -O2/3.
I found this bug was introduced starting from `x86-64 icx-2023.2.0`.
int printf(const char *, ...);
long a;
int *b;
static int **c = &b;
int d;
int *e = &d;
int main() {
  int ***f = &c, ***g = f;
  for (; a >= 0; a--) {
    int **h = &b;
    *h = e;
    for (;;) {
      *b = 0 == &g;
      ***f = 1;
      break;
    **f = *h;
  printf("%d\n", d);
The bug triggered by this test code may be similar to the one I submitted (here's the link: icx error: wrong code at -O3 since `x86-64 icx-2023.2.0` ). If it is the same, and the issue has been fixed in the new icx version, hopefully this test code will help enrich icx test suite.
Also, I was wondering if there is any way to submit test cases to the icx test suite, which I found triggers the icx compiler bugs (i.e. enriching icx test suite)?
Junwei Zeng.
VaishnaviV_Intel
Thanks for posting on Intel communities.
The issue you reported has been addressed in the latest release of oneAPI, version 2024.0.0.
Kindly download it from the provided link:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
We have successfully tested it on icx 2024.0.0, achieving the correct result of 1 with O2 and O3 optimizations. The output is as follows:
If you still have any issues, please let us know.
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
Thanks & Regards,
VaishnaviV_Intel
We have not heard back from you.
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks & Regards,
Junwei_Zeng
Thank you for following up.
The information provided has been helpful, and I consider the issue resolved. You may go ahead and close this thread from your end.
Thanks & Regards,
Junwei Zeng.
VaishnaviV_Intel
Thanks for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
