I need for a project a 128 bit integer data type. As far as I could find out the intel compiler supports __int128 and __uint128. This works fine as long as I do not use %. Here is a complete sample to reproduce the problem:
Environment:
- windows 11, all updates
- intel C++ 2024 latest version
int main()
__int128 l_i128Result = 12345678;
l_i128Result %= 13;
output:
1>R:\ConsoleApplication1\ConsoleApplication1\ConsoleApplication1.cpp(4,11): : warning : variable 'l_i128Result' set but not used [-Wunused-but-set-variable]
1> 4 | __int128 l_i128Result = 12345678;
1> | ^
1>1 warning generated.
1>ConsoleApplication1.obj : : error LNK2019: unresolved external symbol __modti3 referenced in function main
1>R:\ConsoleApplication1\x64\Debug\ConsoleApplication1.exe : : error LNK1120: 1 unresolved externals
1>Done building project "ConsoleApplication1.vcxproj" -- FAILED.
I could not find out which library I need to add to fix this function call.
Thanks for your help.
This issue is resolved with the clang builtins library. You can build the code with the library clang_rt.builtins-x86_64.lib, for example,
icx-cl.exe /Od ConsoleApplication1.cpp clang_rt.builtins-x86_64.lib
This library was not available in the 2024.0 release, but we have it in the 2024.1 release that become available for download now. Please download the 2024.1 release.
I created a new console project for the intel compiler. Add the lines of code and click on compile. I use the intel project template.
Is it that you are asking or does your question point to something else?
@Daniel_D it looks like you used Visual Studio instead of Intel oneAPI command prompt?
Yes- all in VS:
Create a new c++ console project. Add the few code lines. Switch to intel compiler and click on compile.
I already found a workaround and use boost:
#include "boost/multiprecision/cpp_int.hpp"
using namespace boost::multiprecision;
it comes with the types I need.
Hi Daniel:
boost::multiprecision is an arbitrary precision library that does NOT mimic a fixed-sized type like __int128. So any linear algebra you want to do will not have 'nice' memory layouts because the boost::multiprecision are not byte packed. A number system library that does is Universal (https://github.com/stillwater-sc/universal)
There are custom 128bit integers in the Universal Numbers library
In Universal you can ask for a specific integer parameterized in size, for example, integer<128>, for a 128-bit integer. Universal allows for parameterization at single bit precision, so if you want a 97 bit integer, you can get one via the declaration: integer<97>.
Universal is a headers-only lib, so all you would need to do is add the include file:
#include <universal/number/integer/integer.hpp>
and you would be off to the races.
Hope that helps.
Theo
@Daniel_D I've noticed that this problem happens when you use Visual Studio, but if you Intel oneAPI command prompt then there's no problem. Thus I escalated this issue so our developers can take a look.
Hi
i have compile this code fragment under Linux ( OpenSUSE Tumbleweed) with the oneAPI 2024 icx
no problems, no compiler error , nothing all works fine
regards
Franz
Thanks to taking care!
Will switch to Linux later in the project. At the moment I need windows.
I tested the code and got the same error with Debug configuration. But with Release configuration, the code could be built successfully. So as a workaround, you can use Release configuration. In the meantime, I will report the issue to our development team to fix it.
This issue is related to the option "/Od". In the Debug configuration, the default optimization is "/Od", you can change it to "/O1" or "/O2" or "/O3", then the code can run successfully.
Thanks a lot!
