I'm using DevCloud, and I got "JOB SCRIPT ERROR: Remote job failed, code: 1", and I cannot move forward.
I use custom IR model which is generated by Yolov5. The validation dataset is VOC format.
I attached server.log.
Hi takurot,
From the log file you shared with us, it seems like your yolov5 custom model is not able to optimize.
There are a few reasons for it,
- Unsupported layer for yolov5
- The configuration does not match the yolov5 model
- Some other dependency is required, such as .json file and etc
Can I know the configuration you added in the first step (input model) to further debug?
Thank you
Hi takurot,
This thread will no longer be monitored since we have provided a solution. Please submit a new question if you need any additional information from Intel.
Thank you
Topic Options
