I' m not able to open jupyter notebooks (jupyterlab works). When trying to open a notebook, I am getting:
https://jupyter.oneapi.devcloud.intel.com/user/username/tree
I've tried on different browsers with new configs.
Screenshot here: https://imgur.com/a/KC3sY9F
- Tags:
- General Support
Dear Prajjwal,
As we checked team is able to access jupyterhub without any issues, could you please let me know when this issue has started for you ?
This seems to be an temporary issue could you please try again ?
It started when I filed the first issue which you closed today. It's not temporary. I've facing this for past 15 days. Not sure why is not working for me.
It is possible that your account is not configured in that URL. Substitute your account number in the XXXXX below and that will tell JN what account you are using. Since you have more than one account.
Both accounts don't work. You can try u37216. I use this one primarily.
Hi ,
Have you tried accessing above url with your account number as suggested by Hemanth ?
Yes. It gives the same error.
Hi Prajjwal,
We are forwarding this case to concerned team.
Prajjwal, may I please have access to your u37216 account in order to investigate this issue?
No need to post the access key. I just need your permission.
Thanks!
Please go ahead.
Prajjwal, I got in your account, thank you for providing access.
I commented differences between your .bashrc and the default .bashrc that a new account starts with and now Jupyter seems to be working.
For your convenience I also made a backup of the original '.bashrc' under the name '.bashrc.200603'.
Please try it out and let us know how it went.
All the best!
I' still getting the error. 500 : Internal Server Error. I tried to open https://jupyter.oneapi.devcloud.intel.com/user/u37216/notebooks/Welcome.ipynb.
That path is not valid anymore, that's the reason for the error.
DevCloud has switched, some time ago, from Jupyter Notebook to Jupyter Lab.
Please connect to Jupyter using the following link: https://devcloud.intel.com/oneapi/connect/.
Hi Prajjwal,
Have you tried out the solution provided by Dan. Hope this works for you
Arun
We are closing the case assuming that your issues got resolved.Feel free to open a new thread if you face any further issues.
