Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1666 Discussions
Cannot install pandas
BartPigula
I need to run a python script that requires pandas, but python3 on my node can't find it. I was trying to install it with
pip3 install pandas --user
but pip is not found as well - i get the following output:
I've also tried creating env with conda but it failed:
How can i install pandas so i can run my script for example from jupyter cell magic
!python3 script.py
Bartek
DiyaN_Intel
Please follow the steps I've included below to add a new environment to the jupyter notebook.
1. To create an environment -
conda create -n <env_name>
2. Activate the new environment
conda activate <env_name>
3. Install ipykernel
 conda install ipykernel
4. Install pandas
  pip3 install pandas
5. Can view the existing environment list
conda env list
6. Add the new kernel in jupyter notebook
 ipython kernel install --name <env_name> --user
7. Open the jupyter lab and set the kernel to this environment
 Kernel --> change kernel --> select the one you want
This will help you to use the environment that you created in the terminal in jupyter notebook.
If you face any issues please connect back to us.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Diya
DiyaN_Intel
Hi ,
Thank you for posting in Intel communities.
Could you please try setting up oneAPI environment variables forcefully and check once again if it is running properly or not.
Please run the below command:
source /opt/intel/oneapi/setvars.sh --force
Diya
BartPigula
Thanks for the reply,
I did what you suggested and it kind of partially worked: from terminal i was able to run pip3 install pandas --user and the script works good when ran from terminal, but as i try to run the same script but from notebook with command:
!python3 check_finished.py
i still get the message
DiyaN_Intel
4. Install pandas
  pip3 install pandas
conda env list
Diya
DiyaN_Intel
Hi ,
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Diya
