Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1660 Discussions
Help with getting started
ffa
What is the difference between OneAPI/Edge/FGPA? I saw we can launch jupyter from oneapi as well as edge? Can some please help
RemyaP_Intel
Intel DevCloud is a data center grade cluster that allows you to develop and test your projects with the Intel OneAPI based toolkit. The toolkit offers you full native code support across a range of Intel hardware and unifies programming toolkits and libraries across multiple hardware offerings like CPU, GPU, and FPGA. The Intel DevCloud makes it possible for you to get started quickly by offering ways for you to test programming tools before applying them to your code. The Intel DevCloud is a cluster composed of CPUs, GPUs, and FPGAs and has several toolkits pre-installed. Intel DevCloud will be kept up to date with the latest hardware and software from Intel and this allows you to evaluate them soon after release.
The Intel OneAPI DevCloud is a development sandbox to learn about programming cross-architecture applications with OpenVino, and High-Level Design (HLD) tools – OneAPI, OpenCL, HLS – and RTL. You can learn about Data Parallel C++ (DPC++), and Intel® OneAPI Toolkits, Evaluate Workloads, Prototype Your Project and Build Heterogeneous Applications
The Intel Developer Cloud for the Edge is designed to help you evaluate, benchmark, and prototype AI and edge solutions on Intel® hardware. You can test your workload performance with combinations of CPUs, GPUs, and accelerators in bare metal and cloud-native container architectures to identify the hardware platform that works best for your inferencing solutions.
The Intel FPGA DevCloud (Field Programmable Gated Arrays) design development and workloads for hardware acceleration. It can develop programmable solutions and validate your workloads on leading FPGA hardware with tools optimized for Intel technology.
Remya Premdas
RemyaP_Intel
Remya Premdas
ffa
Thank you very much!
RemyaP_Intel
We assume that your query is addressed. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
