Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1659 Discussions
ModuleNotFoundError: No module named 'matplotlib'
ffa
I launched a terminal in jupyter environment. Also created a conda environment and install all the packages. But I am getting module not found error.
Hari_B_Intel
Hi ffa,
For Intel DevCloud for the edge, we are encouraged to use JupyterLab rather than directly execute in the terminal due to the virtual environment in JupyterLab provides almost all the libraries required for OpenVINO.
Once on the Intel® DevCloud pages,
Click on "OpenVINO Work with Intel® Distribution of OpenVINO™ Toolkit".
Scroll down, and you should see "Get Started with JupyterLab."
Click on "Get Started with JupyterLab," and you will see the images attached below,
To get started with the new JupyterLab, scroll down to New Notebooks
Click on any preferred Jupyter Notebooks that suit your application.
In Jupyter Notebooks, you can write your code or launch your test files.
For more information, feel free to refer to View Tutorials
I hope this information helps you.
Thank you
RemyaP_Intel
Could you please tell us which DevCloud you are using? Is it DevCloud for OneAPI/Edge/FPGA?
Remya Premdas
ffa
Hi Remya,
I am begineer and don't know much. How can I find out which one I am using?
I just went to https://www.intel.com/content/www/us/en/developer/tools/devcloud/overview.html and selected jupyter environment. And launched a terminal.
ffa
I think its edge
Hari_B_Intel
Hi ffa,
Thank you
Hari_B_Intel
Hi
This thread will no longer be monitored since we have provided a solution. Please submit a new question if you need any additional information from Intel.
Thank you
