Community
cancel
Showing results for
Search instead for
Did you mean:
Mostafa-
Running intel GPU in Benchmark APP on devcloud
After changing the run the benchmark with GPU to  idc022
print("Submitting a job to an edge compute node with an Intel Core CPU and an Intel GPU...")
#Submit job to the queue
job_id_gpu = !qsub benchmark_app_job.sh -l nodes=1:idc022 -F "results/gpu GPU async"
benchmarks["GPU"] = wait_for_job_to_finish(job_id_gpu)
I faced that error, so it seems like it cannot find the GPU;
213291.v-qsvr-1.devcloud-edge
Job submitted to the queue. Waiting for it to complete .......................................................        Command line parameters
-m                                           /home/u85543/Reference-samples/iot-devcloud/op...
-d        GPU
-niter        10
-api        async
--report_type        detailed_counters
--report_folder                              /home/u85543/Reference-samples/iot-devcloud/op...
Execution results        NaN
error                                        Failed to create plugin /opt/intel/openvino/de...
Please, check your environment                                                             NaN
[CLDNN ERROR]. clGetPlatformIDs error -1001                                                NaN
KeyError                                  Traceback (most recent call last)
/usr/local/lib/python3.6/dist-packages/pandas-1.1.5-py3.6-linux-x86_64.egg/pandas/core/indexes/base.py in get_loc(self, key, method, tolerance)
   2897             try:
-> 2898                 return self._engine.get_loc(casted_key)
   2899             except KeyError as err:
pandas/_libs/index.pyx in pandas._libs.index.IndexEngine.get_loc()
pandas/_libs/hashtable_class_helper.pxi in pandas._libs.hashtable.PyObjectHashTable.get_item()
KeyError: 'throughput'
The above exception was the direct cause of the following exception:
<ipython-input-23-bdcb7714c30e> in <module>
      2 #Submit job to the queue
      3 job_id_gpu = get_ipython().getoutput('qsub benchmark_app_job.sh -l nodes=1:idc022 -F "results/gpu GPU async"        ')
----> 4 benchmarks["GPU"] = wait_for_job_to_finish(job_id_gpu)
<ipython-input-10-cf79f2651227> in wait_for_job_to_finish(job_id)
     24         print(df)
     25
---> 26         throughput = float(df.loc["throughput"][0])
     27         device = df.loc["target device"][0]
     28         load_time = float(df.loc["load network time (ms)"][0])
/usr/local/lib/python3.6/dist-packages/pandas-1.1.5-py3.6-linux-x86_64.egg/pandas/core/indexing.py in __getitem__(self, key)
    877
    878             maybe_callable = com.apply_if_callable(key, self.obj)
--> 879             return self._getitem_axis(maybe_callable, axis=axis)
    880
    881     def _is_scalar_access(self, key: Tuple):
/usr/local/lib/python3.6/dist-packages/pandas-1.1.5-py3.6-linux-x86_64.egg/pandas/core/indexing.py in _getitem_axis(self, key, axis)
   1108         # fall thru to straight lookup
   1109         self._validate_key(key, axis)
-> 1110         return self._get_label(key, axis=axis)
   1111
   1112     def _get_slice_axis(self, slice_obj: slice, axis: int):
/usr/local/lib/python3.6/dist-packages/pandas-1.1.5-py3.6-linux-x86_64.egg/pandas/core/indexing.py in _get_label(self, label, axis)
   1057     def _get_label(self, label, axis: int):
   1058         # GH#5667 this will fail if the label is not present in the axis.
-> 1059         return self.obj.xs(label, axis=axis)
   1060
   1061     def _handle_lowerdim_multi_index_axis0(self, tup: Tuple):
/usr/local/lib/python3.6/dist-packages/pandas-1.1.5-py3.6-linux-x86_64.egg/pandas/core/generic.py in xs(self, key, axis, level, drop_level)
   3491             loc, new_index = self.index.get_loc_level(key, drop_level=drop_level)
   3492         else:
-> 3493             loc = self.index.get_loc(key)
   3494
   3495             if isinstance(loc, np.ndarray):
-> 2900                 raise KeyError(key) from err
   2901
   2902         if tolerance is not None:
Seeking your support please
Mostafa
ChrisB_Intel
I am currently investigating, I will let you know what I find out.
ChrisB_Intel
I confirmed that there is an issues with the 022 node. It is being looked at/worked on right now. Please try a different node and let me know if that works for you.
Chris
Mostafa-
yes, I tried 030, but it takes so infinite time in processing
ChrisB_Intel
My apologies, I am not following your response. Are you saying it does process but takes a long time, or are you saying it does not process at all?
Chris
Mostafa-
no it takes time in the processing without displaying results!
Mostafa-
Any update please
ChrisB_Intel
Thanks for the additional information, this is what we needed. I have opened a bug on it. I will keep you updated.
Chris
