Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1659 Discussions
can't submit job via qsub on devcloud for the edge
kunger
I'm trying to submit a task through qusb, my command is qsub -I -l nodes=1:intel-data-center-gpu-flex-170,walltime=5:00:00 -d . but the system returns an error :qsub: submit error (Job rejected by all possible destinations (check syntax, queue resources, ...))
I see the node is free via pbsnodes, Please tell me how to troubleshoot the error
Iffa_Intel
could you clarify:
  1. Your reference to those steps (URL, etc)
  2. Detailed steps and commands that you did till point of issue
  3. Your use case
Cordially,
Iffa
kunger
I am not sure what to clarify. As I tried to execute the command, I am using qsub to apply for a node with intel-data-center-gpu-flex-170, on which I hope to run LLM inference. My question is why this command would fail, since I am sure that the node with intel-data-center-gpu-flex-170 is idle, and I have confirmed the status of the node using the pbsnodes command. Therefore, I would like to ask why this command would fail. Is it because the walltime I set when applying is too high? If so, what is the maximum walltime for requesting a node on Intel devcloud for the edge? Or is there something wrong with my command?
Iffa_Intel
In that case, could you try:
Add to bash script: # PBS -l walltime=24:00:00
and run qsub again
Try to increase or decrease your walltime to see if it makes any differences.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
