Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1655 Discussions
cl::sycl::compile_program_error
Viet-Duc
Dear Support Team,
I am having a runtime error when running a SYCL code on GPUs queue.
The code is attached below. It compiled and run correctly on login node.
I was able to run the code without issues last week.
Steps to reproduce the problem (s012-n0001)
qsub -I -l nodes=iris_xe_max:quad_gpu:ppn=2
dpcpp -O2 matmul.cpp -o matmul.x
The error message is for level-zero backend is:
 SYCL_PI_TRACE=1  ./matmul.x
SYCL_PI_TRACE[basic]: Plugin found and successfully loaded: libpi_opencl.so
SYCL_PI_TRACE[basic]: Plugin found and successfully loaded: libpi_level_zero.so
SYCL_PI_TRACE[all]: Selected device ->
SYCL_PI_TRACE[all]:   platform: Intel(R) Level-Zero
SYCL_PI_TRACE[all]:   device: Intel(R) Iris(R) Xe MAX Graphics [0x4905]
terminate called after throwing an instance of 'cl::sycl::compile_program_error'
  what():  The program was built for 1 devices
Build program log for 'Intel(R) Iris(R) Xe MAX Graphics [0x4905]':
Internal linker error -11 (CL_BUILD_PROGRAM_FAILURE)
Aborted
The error message is for opencl backend is:
SYCL_PI_TRACE=1 SYCL_DEVICE_FILTER=opencl:gpu ./matmul.x
SYCL_PI_TRACE[all]:   platform: Intel(R) OpenCL HD Graphics
Internal linker error -42 (CL_INVALID_BINARY)
Aborted
Perhaps there is some recent changes that I am not aware of.
You advices are much appreciated.
Regards.
JananiC_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
JananiC_Intel
Thanks for posting in Intel forums.
We are looking into this. We will get back to you soon.
Janani Chandran
Viet-Duc
Dear Janani,
Thanks for looking into the problem.
I would like to give some updates on the problem.
I think the error is probable associated with calling std::rand() on the GPU, as showing in the code snippet below:
SYCL_EXTERNAL int rand();
queue.submit([&](auto &handle) {
        handle.parallel_for(range(m, p), [=](auto index) {
            int i = index[0];
            int j = index[1];
            A_USM[i*p+j] = (float)rand()/(float)RAND_MAX;
    queue.wait();
(Per SYCL standard, I had to declare rand() with SYCL_EXTERNAL attribute)
The problem is solved by initialization all the matrix on the host.
 random_matrix<float>(A_USM, m, p);
If you have other comments, please let me know. Otherwise, I think the issue could be closed.
Once again, thanks for your time.
Regards.
JananiC_Intel
Janani Chandran
