Now, I am going through the training on 'Llama 2 optimization' in 'https://console.cloud.intel.com/training'. How resolve this error appeared while doing Lab 2. Please help....
Hi Shanavas,
Kindly provide us with the link of the training you are going through for further investigation of the error.
Luwe
Hi Shanavas,
Thank you for the links provided. We have informed the relevant team about this issue for further investigation and will update you as soon as possible.
Luwe
Hi Shanavas,
Based on the error message, bigdl-core-xe-21 version 2.5.0b20240407 is no longer available in the repository. Therefore, could you try to install the latest version by following the instructions below?
In the folder, kindly find "requirements.txt" and open the file. In line 16, you should be able to see bigdl-core-xe-21. Please change the version to the latest version, "bigdl-core-xe-21==2.5.0b20240520" and execute "requirements.txt".
Do let us know if this resolves the error.
Luwe
Hi Shanavas,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Luwe
