Intel® Developer Cloud
Help connecting to or getting started on Intel® Developer Cloud
101 Discussions
XGBoost Jupyter Notebook: ModuleNotFoundError: No module named 'sklearn'
TGWelcome
I am beginning the XGboost Jupyter notebook exercise but get this error:
ModuleNotFoundError                       Traceback (most recent call last)
Cell In[11], line 1
----> 1 import sklearn
      2 from sklearnex import patch_sklearn
      3 patch_sklearn()
 When I run this code:
import sklearn
patch_sklearn()
#unpatch_sklearn()
from sklearn.model_selection import train_test_split
from sklearn.metrics import mean_squared_error
import warnings
warnings.simplefilter(action='ignore', category=FutureWarning)
import pandas as pd
from pandas import MultiIndex, Int16Dtype # if you don't import in this order you will get a pandas.Int64Index fix for FutureWarning error.
import xgboost as xgb
import numpy as np
from time import perf_counter
print("XGB Version : ", xgb.__version__)
print("Scikit-Learn Version : ", sklearn.__version__)
print("Pandas Version : ", pd.__version__)
Apparently sklearn doesn't exist in the python kernel?
Labels (3)
Zulkifli_Intel
Hi TGWelcome,
We are investigating this issue and will update you soon.
Zulkifli
Zulkifli_Intel
Hi TGWelcome,
I just ran the training again and the error has been resolved. Please help to rerun the Intel AI Kit and XGBoost Jupyter Notebook and see if a similar issue persists on your side.
If the issue still persists, please do this and try:
and also remove ~/.local/lib/python3.9 if that is not required so that a clean local install would happen.
Zulkifli
Zulkifli_Intel
Hi TGWelcome,
Are you able to run the AI Kit XGBoost Predictive Modeling training now? Please share with us the result from your end.
Zulkifli
Zulkifli_Intel
Hi, this thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Zulkifli
