Dear Sir or Madam,
Excuse me for my dumb question as I'm new to AI domain.
I'm doing some simple benchmark to some LLM models on my company's hardware. I cloned some LLM models (for example, mistral-7b-instruct-v0.1-int8-ov) from HF openvino page (for example, https://huggingface.co/OpenVINO/mistral-7b-instruct-v0.1-int8-ov).
When I ran it, it showed I need to provide data shapes as "input_ids" is dynamic. The typical error message is as follows.
Exception: Input input_ids is dynamic. Provide data shapes!
I have read some docs online (mainly at "https://docs.openvino.ai/"), but still could not figure it out.
For an IR format LLM model, how could I figure out what data shapes I should provide? For a new LLM model on HF, I tried to convert it to IR format by adding data shapes but always failed. Do you have a step-by-step example to show me how to do it?
Your prompt response is appreciated!
Kevin
Hi KW5,
Thanks for reaching out.
For LLM models you can specify the shape value using the parameter -shape "input_ids[1,1],attention_mask[1,1],position_ids[1,1],beam_idx[1]"
Aznie
Hi Aznie,
Many thanks for your reply!
Once I applied that input shape, I got the following error message. Could you advise what I should do? Thanks a lot!
[Step 7/11] Loading the model to the device
[ ERROR ] Exception from src/inference/src/cpp/core.cpp:104:
Exception from src/inference/src/dev/plugin.cpp:53:
Exception from src/plugins/intel_cpu/src/cpu_memory.cpp:410:
Can not create StaticMemory object. The memory desc is undefined
File "/home/amd/openvino_env/lib/python3.12/site-packages/openvino/tools/benchmark/main.py", line 408, in main
compiled_model = benchmark.core.compile_model(model, benchmark.device, device_config)
File "/home/amd/openvino_env/lib/python3.12/site-packages/openvino/runtime/ie_api.py", line 543, in compile_model
super().compile_model(model, device_name, {} if config is None else config),
RuntimeError: Exception from src/inference/src/cpp/core.cpp:104:
Hi Aznie,
Btw, I just noticed from your screenshot that you ran your LLM on GPU. But in my case, I tried to benchmark it on CPU and got that error ("Can not create StaticMemory object. The memory desc is undefined").
Thanks again!
Kevin
Hi Aznie,
I just googled the internet and one posting recommends to using llm_bench tool for LLM models instead of using benmark_app. I will try it and let you know. Thanks!
-Kevin
Hi KW5,
How do you download the models and generate the IR files? I didn’t observe any error when running on the CPU plugin. Below is the result when I ran on CPU:
Aznie
Hi Aznie,
Which model are you running with your above example?
I downloaded existing openvino models from https://huggingface.co/OpenVINO website, and I used
"git clone" to download them.
Could you teach me your regular way to download and convert a model? Thanks!
-Kevin
Hi KW5,
I am using optimum-cli command to download LLM models. However, you can also use Git clone. I observed the same error when running the mistral-7b-instruct-v0.1-int8-ov models with the shapes parameter. I have tried with llm_bench and encountered the error below:
I will check this with the developer and get back to you soon.
Aznie
Hi Kevin,
could you give me more details of your setup so I can pick the best machine for reproducing your issue?
- OpenVINO package version
- compute runtime driver version if you're using one
- Ubuntu or other OS version
- CPU architecture, eg. Elkhart Lake
- other details that you consider important
Thank you in advance,
Hi Kevin,
Can I have your setup details please?
Hi Kevin,
could you share your setup details with us please?
Hi Kevin,
please share your setup details with me. Otherwise I won't be able to reproduce your case and will have to close it without response in 3 business days.
This is a reminder that your setup details are needed to reproduce the issue.
Hi Witold_Intel,
Excuse me for my late response as I was on vacation last couple of days. My setup is not special, and just a regular x86 server with Ubuntu 24.04.
Aznie (above) said he could reproduce the issue, and I'm waiting for his further feedback.
At the same time, I can use "llm_bench" tool to conduct some LLM related testing. So I'm good now.
I met some other questions, I will initiate a new thread as it is a new question.
Thank you for your response. Indeed, Aznie has tried to reproduce, I can see it now. In this case I can open a Jira issue with OpenVino developers to investigate further. Can you post the link to the other topic here for completeness?
Hi Kevin, did you open a new thread or can we continue to support you in the current one?
Hi Kevin,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
