I am trying to install ncsdk2 in an Ubuntu 16.04 virtual machine with Ubuntu 18.04 as host. The Official guide do not mentions this as tested. Since I have no mentioned OSs installed in my machine, decided to try my luck. But, resulted in the following error.
./uninstall-opencv.sh
OpenCV uninstall starting
[sudo] password for sreerag:
Reading installer configuration variables from ./ncsdk.conf
OpenCV uninstall finished
make install starting.
./install.sh
Movidius Neural Compute Toolkit Installation
Installer NCSDK version: 2.10.01.01
print_ncsdk_config()
INSTALL_DIR - Main installation directory
INSTALL_CAFFE - Flag to install TensorFlow
CAFFE_FLAVOR - Specific 'flavor' of caffe to install
CAFFE_USE_CUDA - Use CUDA enabled version of caffe
INSTALL_TENSORFLOW - Flag to install TensorFlow
INSTALL_TOOLKIT - Flag to install Neural Compute Toolkit
PIP_SYSTEM_INSTALL - Globally install pip packages via sudo -H
VERBOSE - Flag to enable more verbose installation
USE_VIRTUALENV - Flag to enable python virtualenv
MAKE_NJOBS - Number of processes to use for parallel build (i.e. make -j MAKE_NJOBS)
INSTALL_DIR=/opt/movidius
INSTALL_CAFFE=yes
CAFFE_FLAVOR=ssd
CAFFE_USE_CUDA=no
INSTALL_TENSORFLOW=yes
INSTALL_TOOLKIT=yes
PIP_SYSTEM_INSTALL=yes
VERBOSE=yes
USE_VIRTUALENV=no
MAKE_NJOBS=1
Didn't find a valid NCSDK installation
Searching and removing previous NCSDK installation from the system
Searching and removing NCS python API...done
Searching and removing udev rules...done
Running ldconfig...done
Updating udev rules...done
Successfully uninstalled NCSDK from the system
Downloading NCSDK-2.10.01.01.tar.gz
Installation failed: Command 'wget -q --no-cache -O NCSDK-2.10.01.01.tar.gz https://downloadmirror.intel.com/28532/eng/NCSDK-2.10.01.01.tar.gz' return code=4. Error on line 324 in ./install-utilities.sh. Will exit
Makefile:47: recipe for target 'install' failed
make: *** [install] Error 131
Is this an hint that the installation won't work with this combination of host and guest or something else?
Hi @sreerag_ibtl
I have not tested this setup before. What software are you using to create the virtual machine? I could give it a try and let you know my results.
Also, have you tried using docker? Take a look at the following link: https://movidius.github.io/ncsdk/docker.html
Jesus
@Jesus_at_Intel I don't have any prior experience with docker. So let me ask, is it possible to install and run NCSDK in ubuntu 18.04 using a docker container.
Hi @sreerag_ibtl
Good news! I was able to install the NCSDK on an Ubuntu 16.04 Virtual Machine (Guest) running on an Ubuntu 18.04 (Host).
Looking at your error: Command
, it appears to be a network issue with your VM. Could you check your network settings and make sure you can ping google or our download page?
ping downloadcenter.intel.com
Jesus
