6392 Discussions
Downloading old Openvino kit releases?
tmatsuzawa
Hello!
I happend to try out Openvino kit R1.0.1 today (for comparison with the latest releases), but R1.0.1 seems to be a bit old and I cannot find it on the download server (below).
https://storage.openvinotoolkit.org/repositories/openvino/packages/
Is there any archive that has this old version?
Or, building from the source is the only way (how)?
Megat_Intel
Hi Tmatsuzawa,
For your information, OpenVINO™ 2019 R1.0.1 release package is no longer available to download. However, you can still build from source OpenVINO 2019_R1.0.1 from the OpenVINO™ GitHub page.
On another note, to build the OpenVINO™ 2019 R1.0.1 Inference Engine you can refer to the guide here.
Megat
Megat_Intel
Hi Tmatsuzawa,
Megat
tmatsuzawa
Hello.
Thank you for your suggestion.
I could built inference-engine tree from the source, but I am curious how its result differs from the R1.0.1 kit package.
In particular, I could not find scripts/setupvars.sh file or INSTALLDIR, INTEL_OPENVINO_DIR environment variables (where they should be set, etc.)
I wonder:
1)scripts/setupvars.sh did not exist in the R1.0.1 package?
2)make install installs libaries in /usr/local/..., not in /opt/intel
Did R1.0.1 package have installer scripts which I could not find in the inference-engine source tree?
Or, there were not such thing?
Megat_Intel
Hi Tmatsuzawa,
Setting up the Environment Variables is only required when OpenVINO™ is installed from the package installer. It is not required when building from source since it is already done in Step 5 of the Build Steps for Linux. Both the "/opt/intel" folder and installer scripts are also only used when OpenVINO™ is installed through the package installer.
For your information, I have built from source OpenVINO™ 2019 R1.0.1 and validated the OpenVINO™ build by running the benchmark app in the bin directory. I show my result below:
Megat
tmatsuzawa
Hello.
Yes, I also could build and app like benchmark_app are in openvino/inference-engine/intel64/Release.
This is fine so far.
My concern is that 3rd party apps built for OpenVINO may expect environment variables set by setupvars.sh, (though whcih I am not sure if it existed for R1.0.1).
Example:
https://wiki.seeedstudio.com/ODYSSEY-X86J4105-Intel-OpenVINO/
It says the follows:
>Set the Environment Variables
>You must update several environment variables before you can compile and run OpenVINO™ applications. Run the following script to temporarily set your environment variables:
I would like to know what is equivalent of this for R1.0.1 built from source.
(If it is the case that R1.0.1 did not have it, then it is fine but I am happy if I can be sure.)
Megat_Intel
Hi Tmatsuzawa,
The guide you provided installed OpenVINO™ from the package installer, and is required to run the setupvars.sh script to temporarily set the environment variables.
When building OpenVINO™ 2019 R1.0.1 from source, you are already setting the environment variable in Step 5 of the Build Steps for Linux, therefore setupvars.sh script is not needed.
For your information, I was able to run the benchmark app in the previous reply without running any setupvars.sh script.
Megat
tmatsuzawa
Ok, thank you very much.
I think I can follow this as common understandind and 3rdpary replying on any further (undocumented) behavior of old package may need adjustment.
Megat_Intel
Hi Tmatsuzawa,
Thank you for your question. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Megat
