Community support and discussions about the Intel® Distribution of OpenVINO™ toolkit, OpenCV, and all things computer vision-related on Intel® platforms.
6017 Discussions
Framework error when converting a HDF5 model into OpenVINO IR format model
nat98
I have a CNN-LSTM model and would like to convert it into the OpenVINO IR format. I have saved the trained model in an HDF5 format with model checkpoint also in the same HDF5 format.
The following code is used to convert the model using Model Optimizer:
python3 mo_tf.py --input_model <directory>/cnn_lstm_model.hdf5 --output_dir <directory>/disaster --input_shape [60,160,160,3] --input_checkpoint <directory>/model_checkpoint.hdf5
However, the conversion is not successful and I got this error:
[ FRAMEWORK ERROR ] Cannot load input model: Unable to open table file <directory>/model_checkpoint.hdf5: Data loss: not an sstable (bad magic number): perhaps your file is in a different file format and you need to use a different restore operator?
I am using Openvino version 2021.4 & TensorFlow version 2.1.0. Any help would be great.
nat98
Peh_Intel
Hi nat98,
Thanks for sharing your models with us.
I also encountered the same error when converting your shared SavedModel format files into IR. Then, I serialized the HDF5 format model into SavedModel format and successfully converted into IR. I found that my converted saved_model.pb file is 1727KB while yours is just 559KB.
I share my steps here:
1.      Install the prerequisites for TensorFlow 2:
cd /opt/intel/openvino_2021.4.582/deployment_tools/model_optimizer/install_prerequisites
./install_prerequisites_tf2.sh
2.      Serialize the HDF5 format model into SavedModel format:
import tensorflow as tf
from tensorflow.keras.models import load_model
model = load_model(‘path/cnn_lstm_model.hdf5’)
tf.saved_model.save(model,'model')
3.      Convert SavedModel format into IR:
python3 mo_tf.py --saved_model_dir <path_SavedModel> --input_shape [1,60,160,160,3]
Link to SavedModel format and IR:
https://drive.google.com/file/d/114MxoDn7GjJ4GqWsZ9A4cgIB4cAZU1kF/view?usp=sharing
Peh
Peh_Intel
Hi nat98,
For model in the HDF5 format, you have to load the model using TensorFlow 2 and serialize it in the SavedModel format. Here is an example of how to do it:
model = tf.keras.models.load_model('model.h5')
Then convert the the SavedModel format into Intermediate Representation (IR) using Model Optimizer:
python3 mo_tf.py --saved_model_dir <SAVED_MODEL_DIRECTORY> --output_dir <OUTPUT_MODEL_DIR>
For more information, you can refer to Convert TensorFlow 2 Models.
Peh
nat98
Hi Peh,
Thanks for your reply.
I have tried the method to load the model using TensorFlow 2 and serialize it in the SavedModel format as shown in your reply.
model = tf.keras.models.load_model('cnn_lstm_model.h5')
I got an error when I run the above code. Attached is the output of the terminal when I run the conversion. The error is exactly the same whether the model is in cnn_lstm_model.h5 format or in cnn_lstm_model.hdf5 format.
For your information, the second attachment is my model summary.
nat98
Peh_Intel
Hi nat98,
Based on your first attachment, I found that your encountered error might be due to h5py version ==3.0.0 which causes issues with Keras model loads in Tensorflow 2.1.0.
Please try to downgrade the h5py package with the following command:
pip install 'h5py==2.10.0' --force-reinstall
Here are two similar discussions that you can refer to:
h5py==3.0.0 causes issues with keras model loads in tensorflow 2.1.0
Does Any one got "AttributeError: 'str' object has no attribute 'decode' " , while Loading a Keras S...
Peh
nat98
Hi Peh,
Thanks for your suggestion, I have downgraded the h5py package to version 2.10.0. This solved the "Attribute Error" issue. Thanks for that.
I load the model using TensorFlow 2 and serialize it in the SavedModel format, and converted it successfully.
Now, when I convert to OpenVINO IR using the following code:
OR
python3 mo_tf.py --saved_model_dir <SAVED_MODEL_DIRECTORY> --output_dir <OUTPUT_MODEL_DIR> --input_shape [60,160,160,3]
I got the following errors:
[ ERROR ] Cannot infer shapes or values for node "StatefulPartitionedCall_1".
[ ERROR ] Expected DataType for argument 'dtype' not <class 'str'>.
[ ERROR ]
[ ERROR ] It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x7f39a20a4620>.
[ ERROR ] Or because the node inputs have incorrect values/shapes.
[ ERROR ] Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ] Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "StatefulPartitionedCall_1" node.
For more information please refer to Model Optimizer FAQ, question #38. (https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html?q...)
Attached is the screenshot of the terminal.
nat98
nat98
Hi Peh,
I have downgraded the h5py package. It solved the error that I have during the model conversion from hdf5 to pb file format.
I run the following codes:
or
And I got some errors during the conversion to OpenVINO IR. Here are some of the errors:
Attached is the screenshot of the full error.
nat98
Peh_Intel
Hi nat98,
Sorry for my late response.
Could you share the models (hdf5 and SavedModel format) with us for further investigation?
Peh
nat98
Hi Peh,
Thanks for your response.
The link to my models in both hdf5 and SavedModel format are as follows:
HDF5: https://drive.google.com/file/d/1ePuQrVXNA1diNEOvNlqvSYZ7RTOzncIZ/view?usp=sharing
SavedModel: https://drive.google.com/file/d/1ehp6dJ9uNEY13yIzI_OtVsXiSbxYDsdd/view?usp=sharing
Note that I could not attach my model in this reply due to the maximum size allowed.
nat98
Peh_Intel
Hi nat98,
Peh
nat98
Hi Peh,
I followed your steps and indeed after installing/upgrading TensorFlow 2 prerequisites, the converted saved_model.pb file is 1.8 MB.
Also, I am able to convert the said model into the OpenVINO IR format.
Thanks a lot for your time in solving my issues.
nat98
Peh_Intel
Hi nat98,
Glad to hear everything works well to you.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
