Hello I faced with the problem when trying to use Movidius stick with tensorflow. I have keras model and I convert it to tensorflow model. When I convert it to Movidius graph I got error:
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 290, in parse_tensor
if have_first_input(strip_tensor_id(node.outputs[0].name)):
IndexError: list index out of range
Here is my code:
from keras.models import model_from_json
from keras.models import load_model
from keras import backend as K
import tensorflow as tf
import nn
import os
weights_file = "weights.h5"
sess = K.get_session()
K.set_learning_phase(0)
model = nn.alexnet_model() # get keras model
model.load_weights(weights_file)
saver = tf.train.Saver()
saver.save(sess, "./TF_Model/tf_model") # convert keras to tensorflow model
tf_model_path = "./TF_Model/tf_model"
fw = tf.summary.FileWriter('logs', sess.graph)
fw.close()
os.system('mvNCCompile TF_Model/tf_model.meta -in=conv2d_1_input -on=activation_7/Softmax') # get Movidius graph
Python version: 2.7
OS: Ubuntu 16.04
Tensorflow version: 1.12
@jenamax Thanks for providing your code. Can you Which version of the NCSDK are you using? If you could provide me with your model files, that would be helpful and save me a lot of time also.
Hello im facing the same problem
i work with keras/tensorflow. just finetune a yolov3 (416) for custom data. everything fine in the host with the camera.
i use the same code of @jenamax for transform keras->tf. I get the .meta .index .dataXXXX checkpoint as expected.
i run in vm ubuntu16.04 8gb with ncsdk 1 the command
mvNCCompile tfmodel.meta -s 12 -in input_1 -on conv2d_59/conv2d_67/conv2d_75
In the model.json says that outputs layers are those 3
conv2d_59
conv2d_67
conv2d_75
but getting [ERROR 13] outputs conv2d_59/conv2d_67/conv2d_75 not as expect…
any help?
@Tome_at_Intel
hello im facing the same problem
here is my model.json (yolov3) : https://drive.google.com/file/d/1syNkwSEro0mElDQ34uihPZDIBGpw4bor/view?usp=sharing
when I type " mvNCCompile TF_Model/tf_model.meta -in input_1 -on conv2d_75/kernel -s 12 "
It gives me :
"input_data = np.random.uniform(0, 1, shape)
File "mtrand.pyx", line 1302, in mtrand.RanomState.uniform
File "mtrand.pyx", line 242, in mtrand.cont2_array_sc
TypeError: 'NoneType' object cannot be interpreted as an integer
I'm not sure if the output_node 's name is "conv2d_75", because the model.json says that outputs layers are those 3
conv2d_59
conv2d_67
conv2d_75
but i think it's doesn't matter. now i just want to know how to solve this "Type Error"
and i don't know if the yolov3 is supported by ncs? it seems to have three outputs.
Thank you very much!
