We have followed the instructions given in below link to run llama2-7b also we have tried with nightly version but in both the approach we are facing similar error "File not found: openvino_tokenizer.xml". When we are trying to install openvino_tokenizer we are getting lot of errors. Could you please let us know if there is any other way to run llama model with openvino_genai
https://docs.openvino.ai/2024/learn-openvino/llm_inference_guide/genai-guide-npu.html
Hi Shravanthi,
Thanks for reaching out. Can you share the screenshot of your TinyLlama directory? Does openvino_tokenizer (.xml and .bin) files available in the directory? I have exported the TinyLlama but the files are not available from my end. When exporting the LLM models, the directory should include the openvino_tokenizer files. Below are the files when exporting mistral-7b-instruct-v0.1-int8-ov model:
Aznie
Hi Aznie,
We are also facing same issue when we exported TinyLlama and Llama2-7b models openvino_tokenizers and openvino_detokenizers files are not available in the directly. We tried to use these tokenizers files from another source of Llama2-7b but we got Error: Cannot create SpecialTokensSplit layer, below is the screenshot of error
Hi Sharavanthi,
We are checking this with the development team and will get back to you soon.
Aznie
Hi Aznie,
Do you have any update on this ?
Shravanthi
Hello Shravanthi,
Your case is currently with me. I opened an issue with OpenVINO developers to discuss the details. I will get back to you as soon as I know more.
Hello Shravanthi,
I didn't receive any response from the developers yet. Please bear with us.
Our developer was able to replicate your case, here's the output:
(venv20245) apaniuko@IRL-ODT-08:~/python/openvino_tokenizers/benchmark$ optimum-cli export openvino -m TinyLlama/TinyLlama-1.1B-Chat-v1.0 --weight-format int4 --sym --group-size 128 --ratio 1.0 TinyLlama
`loss_type=None` was set in the config but it is unrecognised.Using the default loss: `ForCausalLMLoss`.
We detected that you are passing `past_key_values` as a tuple of tuples. This is deprecated and will be removed in v4.47. Please convert your cache or use an appropriate `Cache` class (https://huggingface.co/docs/transformers/kv_cache#legacy-cache-format)
/home/apaniuko/python/openvino_tokenizers/benchmark/venv20245/lib/python3.10/site-packages/transformers/cache_utils.py:458: TracerWarning: Using len to get tensor shape might cause the trace to be incorrect. Recommended usage would be tensor.shape[0]. Passing a tensor of different shape might lead to errors or silently give incorrect results.
or len(self.key_cache[layer_idx]) == 0 # the layer has no cache
/home/apaniuko/python/openvino_tokenizers/benchmark/venv20245/lib/python3.10/site-packages/optimum/exporters/openvino/model_patcher.py:496: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
if sequence_length != 1:
/home/apaniuko/python/openvino_tokenizers/benchmark/venv20245/lib/python3.10/site-packages/transformers/cache_utils.py:443: TracerWarning: Using len to get tensor shape might cause the trace to be incorrect. Recommended usage would be tensor.shape[0]. Passing a tensor of different shape might lead to errors or silently give incorrect results.
elif len(self.key_cache[layer_idx]) == 0: # fills previously skipped layers; checking for tensor causes errors
INFO:nncf:Statistics of the bitwidth distribution:
│ Weight compression mode │ % all parameters (layers) │ % ratio-defining parameters (layers) │
│ int8_asym │ 12% (2 / 156) │ 0% (0 / 154) │
│ int4_sym │ 88% (154 / 156) │ 100% (154 / 154) │
Applying Weight Compression ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 100% • 0:00:40 • 0:00:00
(venv20245) apaniuko@IRL-ODT-08:~/python/openvino_tokenizers/benchmark$ ls TinyLlama/
config.json openvino_detokenizer.bin openvino_model.bin openvino_tokenizer.bin special_tokens_map.json tokenizer.json
generation_config.json openvino_detokenizer.xml openvino_model.xml openvino_tokenizer.xml tokenizer_config.json tokenizer.model
We're suspecting it to be an environment issue. Could you check your packages please? Here's the list from our side:
about-time==4.2.1
aiohappyeyeballs==2.4.3
aiohttp==3.11.8
aiosignal==1.3.1
alive-progress==3.2.0
async-timeout==5.0.1
attrs==24.2.0
autograd==1.7.0
certifi==2024.8.30
charset-normalizer==3.4.0
cma==3.2.2
coloredlogs==15.0.1
contourpy==1.3.1
cycler==0.12.1
datasets==3.1.0
Deprecated==1.2.15
dill==0.3.8
filelock==3.16.1
fonttools==4.55.0
frozenlist==1.5.0
fsspec==2024.9.0
grapheme==0.6.0
huggingface-hub==0.26.2
humanfriendly==10.0
idna==3.10
Jinja2==3.1.4
joblib==1.4.2
jsonschema==4.23.0
jsonschema-specifications==2024.10.1
jstyleson==0.0.2
kiwisolver==1.4.7
markdown-it-py==3.0.0
MarkupSafe==3.0.2
matplotlib==3.9.2
mdurl==0.1.2
mpmath==1.3.0
multidict==6.1.0
multiprocess==0.70.16
natsort==8.4.0
networkx==3.3
ninja==1.11.1.2
nncf==2.14.0
numpy==2.1.3
nvidia-cublas-cu12==12.4.5.8
nvidia-cuda-cupti-cu12==12.4.127
nvidia-cuda-nvrtc-cu12==12.4.127
nvidia-cuda-runtime-cu12==12.4.127
nvidia-cudnn-cu12==9.1.0.70
nvidia-cufft-cu12==11.2.1.3
nvidia-curand-cu12==10.3.5.147
nvidia-cusolver-cu12==11.6.1.9
nvidia-cusparse-cu12==12.3.1.170
nvidia-nccl-cu12==2.21.5
nvidia-nvjitlink-cu12==12.4.127
nvidia-nvtx-cu12==12.4.127
onnx==1.17.0
openvino==2024.5.0
openvino-genai==2024.5.0.0
openvino-telemetry==2024.5.0
openvino-tokenizers==2024.5.0.0
optimum==1.23.3
optimum-intel==1.20.1
packaging==24.2
pandas==2.2.3
pillow==11.0.0
propcache==0.2.0
protobuf==5.28.3
psutil==6.1.0
pyarrow==18.1.0
pydot==2.0.0
Pygments==2.18.0
pymoo==0.6.1.3
pyparsing==3.2.0
python-dateutil==2.9.0.post0
pytz==2024.2
PyYAML==6.0.2
referencing==0.35.1
regex==2024.11.6
requests==2.32.3
rich==13.9.4
rpds-py==0.21.0
safetensors==0.4.5
scikit-learn==1.5.2
scipy==1.14.1
sentencepiece==0.2.0
six==1.16.0
sympy==1.13.1
tabulate==0.9.0
threadpoolctl==3.5.0
tokenizers==0.20.3
torch==2.5.1
tqdm==4.67.1
transformers==4.46.3
triton==3.1.0
typing_extensions==4.12.2
tzdata==2024.2
urllib3==2.2.3
wrapt==1.17.0
xxhash==3.5.0
yarl==1.18.0
You could also try to convert tokenizers separately with this command:
(venv20245) apaniuko@IRL-ODT-08:~/python/openvino_tokenizers/benchmark$ convert_tokenizer TinyLlama/TinyLlama-1.1B-Chat-v1.0 --with-detokenizer --left-padding -o TinyLlama/
Loading Huggingface Tokenizer...
Converting Huggingface Tokenizer to OpenVINO...
Saved OpenVINO Tokenizer: TinyLlama/openvino_tokenizer.xml, TinyLlama/openvino_tokenizer.bin
Saved OpenVINO Detokenizer: TinyLlama/openvino_detokenizer.xml, TinyLlama/openvino_detokenizer.bin
Hi Shravanthi,
Have you been able to try the workaround suggested? Please respond within 5 working days, otherwise I will have to deescalate this issue.
Hello Shravanthi,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
