hii..
am using openVINO in raspberry pi with ncs and also in windows 10..but i cant able to use the opencv that comes with toolkit..will anyone say ho w to use the opencv with openvino...
thank you,
@raj, dilli, Please clarify the problem. You cannot use OpenCV in Raspbian or in Widnows?
actually in both...it shows build opencv with inference engine.and i dont know how to do that..
but i can use opencv separetly in raspbian..i cannot able to use it with the openVINO models..
thanking you.......
@Hyodo, katsuya thank you fro your reply.. i will try those and tell you back.
@Kochar, Amrit
Please try, R5. (not R5.0.1)
Sorry to post here. But, After I install OpenVino, OpenCV is shipped, yes this is correct.
However, I only found OpenCV with python 3.5 and 2.7 API. I want to use python3.6 but not possible.
Under /opt/intel/openvino_2019.1.094/python/
There are five folders with name python3.x.
files like cv2.cpython-35m-x86_64-linux-gnu.so only exist in python3.5 and python 2.7 folder. But not in others such as python3.6....
I also tried uninstall and install for a few times, changing system default python to python3.6... but they all does not work... Could someone help at this point?
Also, is it possible to do conda install or pip install for getting opencv-openvino???
Dear Chen, Cheng,
Hmmm. This is strange. Yes, OpenVino works with Python 3.65 and in fact it's recommended to use with Python 3.6.5. Please avoid Conda installations, at least where OpenVino is concerned. OpenVino can certainly co-exist with Conda on the same machine, but OpenVino relies on a traditional Python installation.
I have a feeling that something got messed up in your installation. Please uninstall all instances of Python and OpenVino on your machine, then follow these steps carefully :
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html
Hope it helps.
Thanks for using OpenVino,
Shubha
Dear Chen, Cheng,
Please see my detailed response in the below forum post. There is nothing inherently wrong with using a Conda installation of Python with OpenVino - OpenVino theoretically should not care, as long as you get your PATH setup correctly. Our official installation instructions do not mention Conda but I can't see why a Conda Python installation would be problematic for OpenVino. The only issue is, your life may be harder - all of the MO and other Python tools use requirements.txt to install prerequisites. Apparently you can do something similar with Conda according to this Stack Overflow question. It's not impossible but it will be more inconvenient, if you use Conda.
https://software.intel.com/en-us/forums/computer-vision/topic/802287
Shubha
Currently we build OpenCV only for default python versions on Linux (python2, python3 packages in the system repository). Theoretically you can try to copy OpenCV python binary from python3.5 folder to python3.6 and rename it, but this method is not guaranteed to work.
Hyodo, Katsuya wrote:@raj, dilli
Sir can you kindlly guide me how to attach opencv with inference engine for raspberry pi
OpenCV is automatically installed without building.
Windows is not tried because it is troublesome.- Procedure for introducing OpenVINO and OpenCV 4.0.1-openvino to RaspberryPi (Raspbian Stretch)
https://github.com/PINTO0309/OpenVINO-YoloV3#2-work-with-raspberrypi-ras...- Below is a sample that uses the OpenCV DNN module to run the OpenVINO model.
https://github.com/PINTO0309/MobileNet-SSD-RealSense/blob/master/SingleS...
