Could I know is it possible to capture the multiple live streams and run the different inference on the each soure (each streams) in open vino?
Thanks and regards,
Nexn.
Hi Nexn,
Thanks for reaching out. It is possible with the DL Streamer multi-stream pipeline, which contains multiple sub-pipelines, each processing one source. You may check these Video streams from multiple cameras.
I hope this helps you.
Aznie
Hi Aznie,
Thanks for your response.
I need to run individual inference in all my multiple live rtsp streams.
In the (source 1) first stream , I want to detect persons only . In the (source 2) second stream, I want to detect other some sort of things rather than persons.
Is that possible in openvino?
Nexn.
Hi Nexn,
Yes, you can perform multi-input and multi-object detection. However, the performance might drop significantly and might not work if too much input video is supplied. The Multi Camera Multi Target Python* Demo is a demo from Open Model Zoo that might suit your objective.
Aznie
Hi Nexn,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
