Dear Sir
I refer to the following information to install the ESDQ,
You can see the ESDQ install success information as below:
***Recommended to reboot system after installation***
| Id | Module | Status |
| 64cb337f89c314c29867e05c | ESDQ | SUCCESS |
Until i do the below step , i can not find the esdq binary.......
Do you have suggestion about it ?
Run the Application
NOTE:
Download and install Intel® ESDQ with the respective test modules before you continue in this section.
Perform the following procedure to run Intel® ESDQ as a complete test suite via the esdq CLI.
Change the directory to the location of Intel® ESDQ.
cd ~/esdq
Check the Intel® ESDQ version.
esdq --version
Ensure the release version matches the version you downloaded. Here's an example of the output.
Add more information
edgesoftware , version 2024.1
Hi Green,
For ESDQ ECI installation, refer to this documentation https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-eci.html
The documentation that you referring to is general ESDQ page, it does not have ECI features.
SShan_Intel
Hi SShan_Intel,
Thanks for sharing your answer in Intel® Edge Software Hub Community.
Hi Geen,
Referring to the answer provided by SShan_Intel, does installing Intel® Edge Software Device Qualification (Intel® ESDQ) for Intel® Edge Controls for Industrial (Intel® ECI) resolve your issue?
Wan
Dear Wan_Intel & SShan_Intel
Thanks for your information.
This issue is already resolved.
Hi Geen,
We are glad to know that your issue has been resolved. We will close this case now. If you need additional information from Intel, please submit a new question.
Wan
![](/skins/images/318B71AC6E18CAB8E2CA944B2397E849/responsive_peak/images/icon_anonymous_message.png)
