Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
414 Discussions
How can I use Telegraf with influxdb
Siyoung
I want to use Telegraf.
Telegraf and Datastore is running.
but I don't know how to set config files.
JesusE_Intel
Hi Siyoung,
Could you run docker ps and verify that the Multimodal Data Visualization microservice is up, you can access Grafana at http://<HOST_IP>:3000. For the user name and password, take a look at the edge_insights_industrial/Edge_Insights_for_Industrial_4.0.0/IEdgeInsights/Visualizer/multimodal-data-visualization/eii/grafana.ini in the security section. This will help you visualize the data.
Jesus
JesusE_Intel
Hi Siyoung,
There is a default telegraf configuration that is loaded, take a look at the [WORK_DIR]/IEdgeInsights/Telegraf/config/Telegraf/Telegraf.conf file. Additional information ca be found in the documentation: Telegraf Overview — EII Documentation v1.0 documentation (intel.com)
There is also an example on how to configure Telegraf and the message bus. Hope this help!
Jesus
Siyoung
Then I want to see visualized data of influxdb, so I changed ifluxdb version 1.8.7 to 2.0.0.
but still I can't see the visualized data in 8086 port.
config of Datastore and influxdb
JesusE_Intel
Hi Siyoung,
Jesus
JesusE_Intel
