Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
407 Discussions
It looks like the MCP251xfD Driver is missing from the Intel ECI Kernel.
YOONJU
Hello My Name is yoonju from south of korea.
I installed the Intel ECI Kernel by referring to the following site.
( When installing the kernel, it was installed with the ECI APT repository.)
https://eci.intel.com/docs/3.0/getstarted/verify_deployment.html#complete-and-verify-deployment
And it booted normally with Intel ECI kernel in Ubuntu 22.04.
Our main purpose here is to use the MCP2518FD Can FD I/F.
However, when I run Modprobe mcp251xfd in the kernel, it says there is no mcp251xfd driver module.
Isn't the corresponding module built in the built-in kernel? How should I solve this case?
Thank you for your reply.
YOONJU
Hello
This issue has been resolved.
The manager(Lay, Kuan Loon ) in charge delivered the guide by e-mail.
https://eci.intel.com/docs/3.0.1/development/kernel_building.html#step-3-build-linux-kernel
Thanks for your help.
YOONJU
Hello
JesusE_Intel
Thanks for the update. If you need any additional information, please submit a new question as this thread will no longer be monitored.
