ALLOCATE with SOURCE curiosity
Ron_B
I have a derived type with an allocatable integer array component.
I have a procedure for initialization that checks and deallocates it, and then will allocate it with a default set of values.
if(allocated(this%wt_sums)) deallocate(this%wt_sums)
allocate(this%wt_sums, source=def_wt_sums)
def_wt_sums is also an allocatable integer array that is initialized upon program execution.
The curiosity happens in that the first time this is executed, it performs correctly.  However, the second time it is called, it fails returning the error message
"forrtl: severe (408): fort: (10): Subscript #1 of the array WT_SUMS has value 140698534922351 which is greater than the upper bound of 14"
 (The value is random, so I'm assuming it's a memory address.)
The bounds of wt_sums are correct, but it appears the source clause is not executing correctly.  Is the difficulty due to using an allocatable array as the source? It works correctly if I use:
allocate(this%wt_sums,mold=def_wt_sums)
this%wt_sums = def_wt_sums
I am using IFX, Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.2 Build 20231213
Ron
Steve_Lionel
Test case, please.
Ron_B
Removed the other 200,000+ lines, but the error remains.
Ron
Ron_B
Interestingly, error does not occur when I use IFORT
Ron
andrew_4619
you also get an error with IFX 2024.1.0 , seems like a bug to me. The allocate at line 6 below gives an error the second time around.
  subroutine t_wtgrouping_init(this)
    class(T_WTGROUPING), intent(inout) :: this
    this%id      = 0
    this%descrip = ''
    !if (allocated(this%wt_sums)) deallocate(this%wt_sums)
    !allocate(this%wt_sums,source=def_wt_sums)
    this%wt_sums = def_wt_sums ! works with realloc
  end subroutine t_wtgrouping_init
Why not use that lovely feature of realloc LHS and save typing that works.  Those good kind Fortran committee people gave is this feature.
jimdempseyatthecove
While it works, it works more often than necessary. Old code that had/has
ArrayOut = (Array Expression)
Would (maybe not now) invariably realloc the LHS even though the expression had the same rank and sizes.
Jim Dempsey
IanH
Fear not - a compiler that did such reallocation would be broken.
Reallocation of the LHS is not permitted by the rules of the language if the shape (and dynamic type) matches.
Ron_B
Thanks!
Aero engineer that has been self-taught Fortran over the years loves discovering things like this.
Steve_Lionel
I sure hope it doesn't reallocate now when it shouldn't - one of the last things I did before I retired was write a new run-time routine to handle this operation.
Barbara_P_Intel
Interesting that you only get the traceback when you compile with /check:bounds. Or in my case on Linux "-check bounds".
And, yes, it occurs with the second call to wr_grp%init().
Ron_B
It appears the bug is with the check array bounds.  If I turn the check off, it performs correctly without a traceback.
Ron
Barbara_P_Intel
I filed a bug report for this, CMPLRLLVM-57391. Stay tuned for an update.
flaxzune
