28892 Discussions
Compiler Bug: cmplx does not handle Y argument correctly
emilybo
New User
The following is a reproducer for the problem:
module intel_bug
implicit none
contains
subroutine to_complex(arr, Out_1, Out_2)
integer(8), intent(in) :: arr(0:)
complex(4), intent(out) :: Out_1
complex(4), intent(out) :: Out_2
complex(4), allocatable :: a(:)
allocate(a(0:size(arr, kind=8) - 1_8))
a = cmplx(arr, 0, kind=4) ! <----------- Problematic line v1
!a = cmplx(arr, 0.0, kind=4) ! <----------- Problematic line v2
!a = cmplx(arr, kind=4) ! <----------- Problematic line fix
Out_1 = a(0_8)
Out_2 = a(1_8)
end subroutine to_complex
end module intel_bug
program my_prog
use intel_bug
integer(8), allocatable :: arr(:)
complex(4) :: test1
complex(4) :: test2
allocate(arr(0:9))
do i=0,9
arr(i) = i
end do
call to_complex(arr, test1, test2)
print *, test1, test2
end program my_prog
The output of the code is:
# v1
(0.0000000E+00,0.0000000E+00) (0.0000000E+00,0.0000000E+00)
# v2
# v3
(0.0000000E+00,0.0000000E+00) (1.000000,0.0000000E+00)
The standard says:
CMPLX (X [, Y, KIND])
Y (optional)    shall be of type integer or real, or a boz-literal-constant. If X is of type
complex, Y shall not be present, nor shall Y be associated with an optional
dummy argument.
If Y is absent and X is not complex, it is as if Y were present with the value
zero
This post may be related: https://community.intel.com/t5/Intel-Fortran-Compiler/ifort-and-ifx-internal-compiler-error/m-p/1620305
Compiler version information:
ifx (IFX) 2024.2.1 20240711
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Ron_Green
We did see the earlier issue.  and we fixed it an it's in the upcoming v2025.0 ifx compiler.  Output matches NAG and Gfortran for cmplx and follows the standard.
$ ifx -what -V cmplx_v1.f90 && ./a.out
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.0 Build 20240930
 Intel(R) Fortran 25.0-1205
GNU ld version 2.41-34.fc40
$ ifx -what -V cmplx_v2.f90 && ./a.out
$ ifx -what -V cmplx_v3.f90 && ./a.out
Ron_Green
