28499 Discussions
Fortran Compiler Bug: overloading binary and unary operator(-) and use with extended types
SebastianM
I came across a strange bug with all Intel-Fortran compilers I tested (Intel 18/19, Intel oneAPI 2023) when overloading the "-" operator for binary AND unary operations (same is also true for "+").
Here is a minimal example for a vector type:
module mo_vec
  type :: vector
    real :: x, y
  contains
    procedure :: diff, neg
    generic :: operator(-) => diff, neg
  end type vector
  interface vector
    procedure init_vec
  end interface vector
  type, extends(vector) :: vector_parameter
  end type vector_parameter
  type(vector_parameter), parameter :: vec_x = vector_parameter(1., 0.)
  type(vector_parameter), parameter :: vec_y = vector_parameter(0., 1.)
contains
  pure type(vector) function init_vec(x, y, factor)
    real, intent(in) :: x, y
    real, intent(in), optional :: factor
    real :: factor_
    factor_ = 1.0
    if (present(factor)) factor_= factor
    init_vec%x = factor_ * x
    init_vec%y = factor_ * y
  end function init_vec
  pure type(vector) function diff(this, that)
    class(vector), intent(in) :: this, that
    diff = vector(x=this%x-that%x, y=this%y-that%y)
  end function diff
  pure type(vector) function neg(this)
    neg = vector(x=-this%x, y=-this%y)
  end function neg
end module mo_vec
program vec_test
  use mo_vec
  print*, vec_x - vec_y
end program vec_test
First: I had to create an extended type vector_parameter in order to be able to create parameter variables of my vector type. Otherwise Intel-Fortran also throws an error, that I can't use the vector interface (which I need to include the "factor" argument) in a constant expression:
main1.f90(19): error #9066: A generic function reference is not permitted in a constant expression.   [INIT_VEC]
  type(vector), parameter :: vec_x = vector(1., 0.)
Compiling this example I get:
main1.f90(59): error #6355: This binary operation is invalid for this data type.   [VEC_X]
main1.f90(59): error #6355: This binary operation is invalid for this data type.   [VEC_Y]
main1.f90(59): error #6549: An arithmetic or LOGICAL type is required in this context.
compilation aborted for main1.f90 (code 1)
When I comment out the neg part of the "-" operator:
generic :: operator(-) => diff!, neg
it works.
I could get it to work, with adding routines to vector_parameter:
  contains
    procedure :: diffp, negp
    generic :: operator(-) => diffp, negp
  pure type(vector) function diffp(this, that)
    class(vector_parameter), intent(in) :: this, that
    diffp = vector(x=this%x-that%x, y=this%y-that%y)
  end function diffp
  pure type(vector) function negp(this)
    negp = vector(x=-this%x, y=-this%y)
  end function negp
 But then, I would also need add routines to subtract vector from vector_parameter and vice versa and it now wont compile with other compilers anymore.
The strange thing is, if I now comment out neg and negp:
    generic :: operator(-) => diffp!, negp
I get the following error (like with gfortran or NAG before):
main1.f90(44): error #5286: Ambiguous generic interface OPERATOR(-): previously declared specific procedure DIFF is not distinguishable from this declaration. [DIFFP]
 So I guess, this is a compiler bug.
Opinions?
Cheers, Sebastian
Steve_Lionel
This may not be a compiler bug, as suggested by commenters in Intel Fortran Compiler Bug: overloading binary and unary operator(-) and use with extended types - Fortran Discourse (fortran-lang.discourse.group)  I have not studied the issue myself.
SebastianM
I still think there is something wrong as @IanH also suggests.
The reason for using an extended type for constant expressions is also discussed here:
https://community.intel.com/t5/Intel-Fortran-Compiler/Custom-constructor-initializing-constant-error-6259-with-IFORT/m-p/1166969/highlight/true#M144683
IanH
There's no apparent need (with what you have shown) for the extended type.
Ditch the extension.  Remove the OPTIONAL argument from the third argument to init_vec and associated logic to set the default value for the factor when the third argument is not present.  Calls to init_vec with two arguments are just duplicating what effectively happens with the structure constructor.
Structure constructors with constant expressions for the component specifications can be used in constant expressions, user provided functions can not.
SebastianM
That is of course true, but I just created an artificial example that is short enough to discuss about. In my application I need the optional argument(s).
One hacky option I may use is to add a flag "constant" to the vector to make the native interface distinguishable from my custom one, so I can use it for parameters:
  type :: vector
    logical :: constant = .false.
    real :: x, y
  contains
  end type vector
  type(vector), parameter :: vec_x = vector(.true., 1., 0.)
Then I don't need the extended type for parameters and I don't run into the described bug.
IanH
Be mindful that the cure is not worse that the disease.
If a construction-like function is unintentionally hiding the desired structure constructor, then the simple solution is to use an identifier other than the type name to access the construction-like function.  You can call it `vector_with_factor` or similar, potentially gaining code clarity.
mic_esp96
"If a construction-like function is unintentionally hiding the desired structure constructor, then the simple solution is to use an identifier other than the type name to access the construction-like function. You can call it `vector_with_factor` or similar, potentially gaining code clarity."
This is exactly what has been suggested in the Fortran Discourse thread as well.
There might be some unclear reasons why the OP wants that optional argument at all costs, but I agree that from what he has provided, that is not actually needed.
SebastianM
That is true. Will keep this in mind. But the described bug still stands.
Thanks for the help.
IanH
Compiler bug. The compiler appears to get confused resolving the generic binding to a specific binding.
mic_esp96
Very likely it is.
This example produces an ICE with both ifort and ifx:
module mo_vec
   type :: vector
      real :: x, y
   contains
      generic :: operator(+) => plus
      procedure :: plus
   end type vector
   interface vector
      procedure init_vec
 contains
      real :: factor_
      factor_ = 1.0
   end function diff
   pure type(vector) function plus(this, that)
      plus = vector(x=this%x+that%x, y=this%y+that%y)
   end function
   end function neg
 end module mo_vec
 program vec_test
   use mo_vec
   print *, vec_x + -vec_y
IanH
Should just be a syntax error.  There's a compiler extension for adjacent add-operands that may be complicating this case.
mic_esp96
@IanH  what should it be a syntax error ?
Steve_Lionel
In: print *, vec_x + -vec_y
the + may not be followed directly by -.  To be conforming, it should be:
print *, vec_x + (-vec_y)
I discuss this in Doctor Fortran in "Order! Order!" - Doctor Fortran (stevelionel.com)
mic_esp96
Oh, I see, my bad.
Thanks for the clarification.
Ron_Green
I'll get a bug report opened for the ICE.  And along with fixing the ICE, let's get an error message like Gfortran.
SebastianM
Thanks for all your help. To remove the discussion about the interface, here is the boiled down version of the problem with the extended type:
module mo_vec
  type :: typ1
    real :: x
  contains
  end type typ1
  ! extended type
  type, extends(typ1) :: typ2
  end type typ2
contains
  pure type(typ1) function diff(this, that)
    class(typ1), intent(in) :: this, that
    diff = typ1(this%x-that%x)
  end function diff
  pure type(typ1) function neg(this)
    neg = typ1(-this%x)
  end function neg
end module mo_vec
program vec_test
  use mo_vec, only: typ2
  type(typ2) :: var1 = typ2(1.), var2 = typ2(2.)
  print *, -var2     ! error #5633: **Internal compiler error
  print *, var1-var2 ! error #6355: This binary operation is invalid for this data type.
Both errors shouldn't come.
Cheers, Sebastian
FortranFan
@SebastianM ,
Which version of the Intel oneAPI with IFORT and IFX generates the ICE with your "boiled down" code?
Ron_Green
Bug ID for the ICE is CMPLRLLVM-48013
