Work environment:
Windows 11 Professional 23H2
VS 2022 community 17.9.6
OneAPI 2024.1
This environment works fine for a long time.
I was running a Fortran program and it paused unexpectly, so I had to close it manually. Then I found out that I cant run no Fortran code at all. It always stopped with this error message:
"No symbol file loaded for libifcoremd.dll"
The console then exterminate itself with no message.
I`ve checked all related posts about it and I`m pretty sure the code is correct.
It now could not even run this simple code correctly:
I`ve reinstalled the oneapi and visual studio. No thing changed.
What message else should I provide to deal with this situation?
I`ve read that post and checked my code before I start this topic, and I`ve shown that I can`t run simple codes already in my original post.
I`ve figured this out by myself. It may be related to some error about the Visual C++ Redistributable. I reinstalled it, reboot, and the code now runs quite fine.
Thanks for your reply anyway, sir, sincerely.
Your program is crashing and the debugger is starting. This is the warning message that there is not a debug version of libifcoremd.dll. It can be ignored. What is happening is that your program is aborting, crashing.
Please try to compile and run a simple Hello World. Or you can set a breakpoint at the start of your program, step through the code, and debug it.
here is an old thread on this message you see https://community.intel.com/t5/Intel-Fortran-Compiler/No-symbol-file-loaded-for-libifcoremd-dll/td-p/1098337
