Hi.
Defining a parameterized derived type PARAMETER, and using it to define another PARAMETER, makes ifx to Never Finish Compiling. Here's the code:
module itemmod
use ISO_FORTRAN_ENV
implicit none
private
save
type, public :: item(ilen, k)
integer, len :: ilen = 0
integer, kind :: k = real32
real(k) :: val = 0
integer :: delta(2) = 0
end type
type(item(1)), parameter, public :: group1 = item(1)(1., [1, 0])
type(item(2)), parameter, public :: group2 = item(2)(1., [0, 1])
type(item(1)), parameter, public :: group1a = group1
contains
end module itemmod
use ISO_FORTRAN_ENV
use itemmod
implicit none
type(item(1)) :: x, v
type(item(2)) :: y, w
print*,'group1=',group1,', ilen=',group1%ilen
print*,'group2=',group2,' ilen=',group2%ilen
end
The issue is caused by line 17. Here's the output from compilation attempt:
$ ifx -V -g -O0 nfc.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Intel(R) Fortran 24.0-1472.3
The command hangs and the linking-related message is never emitted. The same thing happens when using ifort.
The reproducer is based upon code from this post.
@jwmwalrus, thanks for reporting this. I see the same hang with both ifort and ifx. I filed a bug report, CMPLRLLVM-57820.
We'll let you know when it's fixed.
Love the new acronym, NFC!
@Barbara_P_Intel wrote:Love the new acronym, NFC!
Simply changing the order of named constants in the module makes it no big deal, NFC to NBG!
What gives?! Is it one for the front-end team?
module itemmod
use ISO_FORTRAN_ENV
implicit none
private
save
real(k) :: val = 0
end type
type(item(1)), parameter, public :: group1a = group1 !<-- moved up a line
contains
end module itemmod
use ISO_FORTRAN_ENV
use itemmod
implicit none
end
C:\temp>ifx /free /standard-semantics p.f
Microsoft (R) Incremental Linker Version 14.36.32537.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\temp>p.exe
group1= 0.000000 1 0 , ilen= 1
group2= 0.000000 0 1 ilen= 2
Topic Options
