28499 Discussions
Possible bug with non elemental final procedures
Igor666
The following code crashes with segmentation fault on `deallocate(copy)`:
module mytype_mod
  implicit none
  type :: mytype
    integer :: val
  contains
    final :: finalize_mytype
  end type
contains
  subroutine finalize_mytype(this)
    type(mytype), intent(inout) :: this
  end subroutine
end module
program test_prg
  use mytype_mod
  implicit none
  call test()
contains
  subroutine test()
    type(mytype), pointer :: main(:), copy(:)
    allocate(main(3))
    allocate(copy, source = main)
    deallocate(copy)
  end subroutine
end program
If I make the final procedure `elemental`, then it works. This also seems to have something to do with `source` and `pointer` attributes since I couldn't reproduce the crash without them. To the best of my knowledge, this code should be valid. Tested with ifort 19.0.3.199.
FortranFan
This looks like a compiler bug to me.
If you're able to, please submit a support request at Intel OSC: https://supporttickets.intel.com/?lang=en-US
Igor666
