Hello, everyone! I just installed the VS 2022 Community and the oneAPI base toolkit, oneAPI HPC Toolkit. But when I use this to debug my fortran program and set a breakpoint, this program stops at the breakpoint, but I can't see the value of these variables. Anyone has ideas about that?
I have VS 2022 Community and the oneAPI base toolkit, oneAPI HPC Toolkit, installed in March 2022. Everything works OK but not the mouse feature
We ran into this problem - we managed to fix it by updating to the latest version of VS2022 - which was 17.5.5
Hi
If it helps,
I ran into the same issue when debugging in Visual Studio on a Remote System. For that, under "Debug"->"Options...". Load Debug Symbols in External Process (Native Only) needs to be unchecked.
Accept and Upvote my answer if it helps.
Thanks and Regards
Bharath
Worked like a charm! Wish I'd found your answer several days ago!
Thank you, Bharath.
Using Intel Fortran Compiler 2023.2 in VS2022 Version 17.7.6
I just observed the same problem with MVS2022 (17.7.6) and had to manually change the options using the solution proposed by @bharathswami to get the value of variables when hovering over.
2024 Intel Fortran Compiler release will have a better support for later versions of VS 17.7 and this is one of the issues that is fixed in that version.
