28334 Discussions
ifort/ifx bug with allocation of logical array
hkvzjal
I found a small bug with both ifort and ifx compilers when trying to allocate a logical array by negating on a source array. Here a minimal reproducer:
logical, allocatable :: mask(:), nmask(:)
allocate( mask(5) , source = .false. )
allocate( nmask(5), source = .not.mask(:))
end
This prompts:
error #5082: Syntax error, found '.' when expecting one of: ( <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> <INTEGER_CONSTANT> ...
andrew_4619
And this compiles OK so I would agree  there has to be a problem here. The new front end needs a tweak...
allocate( nmask(5), source = ( .not.mask(:) ) )
FortranFan
Presumably
nmask = .not. mask
still works???!!!
andrew_4619
Yes indeed that work ok I will note that  these variants give different errors. It is just not parsing the .not. correctly
allocate( nmask(5), source = .not.mask(:)) ! error #5082
allocate( nmask(5), source = .not.mask) ! errors #6764 and #8155
Ron_Green
This is an interesting case.  I am opening a bug report.  Thanks for finding this.
Ron_Green
bug ID is CMPLRLLVM-54326
