28367 Discussions
"Undefined Pointer/Array" when allocating subelements of (nested) arrays of derived type
Francesco_F
I'm writing a Fortran code (IFORT Intel Fortran Compiler Classic on Visual Studio Community) and I was considering the possibility of defining a nested structure of derived type elements like in the example.
In summary, I have elements like "myGround%LevelA1(nn)%m(d)" where m(:) is ALLOCATABLE, and in principle I don't need LevelA to be ALLOCATABLE.
What I get is that myGround%LevelA1(nn)%m(d) is labeled as "Undefined Pointer/Array"  by the debugger even after allocation. In the end, the code works, also in debug mode, but I assume there is something that confused the debugger.
My question is: what is the best way to define this structure?
My temporary solution is: if the child element m(:) is allocatable, also the mother LevelA(:) should be allocatable.
In the following example I have a derived type tHome, that contains (I apologyze for my use of vocabulary, I hope the reader may understand what I mean. If I write fortran-blasphemies, you are welcome to correct me) other three variables LevelA1, LevelA2 and LevelA3 (of a corresponding derived type tLevelA1, tLevelA2 and tLevelA3). In particular, LevelA1 and LevelA2 are already allocated at the definition ("ALLOCATED"), while LevelA2 is ALLOCATABLE.
All these derived types tLevelA# contain a sub-element, which is an ALLOCATABLE (m(:), n(:) for tLevel1 and tLevel2, respectively) and "ALLOCATED" for tLevel3.
For the variable Level3 (type tLevel3) everything is already allocated, and there is no problem.
For the variable Level2 (type tLevel2) everything is allocatable, and there is not problem.
For the variable Level1 (type tLevel1) the mother (Level1) is "ALLOCATED", while the child m(:) is ALLOCATABLE. After allocation of myGround%LevelA1(nn)%m(d), the debugger shows myGround%LevelA1(nn)%m to be an "Undefined pointer/array", even if the PRINT shows the correct expected results.
This question is partially related to https://community.intel.com/t5/Intel-Fortran-Compiler/Allocatable-Array-of-Inherited-Derived-Types-Issues-in-Fortran/td-p/1012026
many thanks in advance
MODULE MyMod
    IMPLICIT NONE
    PUBLIC
    INTEGER, PARAMETER :: d = 4
    TYPE, public :: tLevelA1
        REAL, ALLOCATABLE :: m(:)
    END TYPE tLevelA1
    type, public :: tLevelA2
        REAL, ALLOCATABLE :: n(:)
    end type tLevelA2
    type, public :: tLevelA3
        REAL :: o(d)
    end type tLevelA3
    TYPE, PUBLIC :: tGround
        TYPE(tLevelA1) :: LevelA1(d)                ! => Debugger is confused (sub-elements are allocatable)
        TYPE(tLevelA2), ALLOCATABLE :: LevelA2(:)   ! => OK (sub-elements are allocatable)
        TYPE(tLevelA3) :: LevelA3(d)                ! => OK (sub-elements are not allocatable)
    END TYPE tGround
    TYPE, PUBLIC ::  tHome
        TYPE(tGround) :: Ground
    END TYPE tHome
    CONTAINS
    function ConstructorHome() Result(myHome)
        IMPLICIT NONE
        type(tHome) :: myHome
        myHome%Ground = ConstructorGround()
    end FUNCTION ConstructorHome
    function ConstructorGround() Result(myGround)
        IMPLICIT NONE
        type(tGround) :: myGround
        type(tLevelA2) :: locA2(d)
        type(tLevelA1) :: locA1(d)
        INTEGER :: nn
        ALLOCATE(myGround%LevelA2(d))
        DO nn=1,d
            ALLOCATE(myGround%LevelA1(nn)%m(d))
            ALLOCATE(myGround%LevelA2(nn)%n(d))
            ALLOCATE(locA1(nn)%m(d))
            ALLOCATE(locA2(nn)%n(d))
        ENDDO
        DO nn=1,d
            myGround%LevelA1(nn)%m(:)       = 10.0  + nn
            myGround%LevelA2(nn)%n(:)       = 20.0  + nn
            myGround%LevelA3(nn)%o(:)       = 30.0  + nn
        ENDDO
        DO nn=1,d
            PRINT *, myGround%LevelA1(nn)%m(:)
            PRINT *, myGround%LevelA2(nn)%n(:)
            PRINT *, myGround%LevelA3(nn)%o(:)
        ENDDO
        PRINT *,"-------------------"
        myGround%LevelA1  = locA1
        myGround%LevelA2  = locA2
        DO nn=1,d
        ENDDO
        DO nn=1,d
        ENDDO
        DO nn=1,d
            DEALLOCATE(myGround%LevelA2(nn)%n)
        ENDDO
    end function ConstructorGround
END MODULE MyMod
PROGRAM mytest
    USE MyMod
    IMPLICIT NONE
    TYPE(tHOME) :: myHome
    myHome = ConstructorHome()
END PROGRAM mytest
Labels (2)
Devorah_H_Intel
@Francesco_F  The fix is in recently released compiler, part of HPC Toolkit 2023.2
FortranFan
@Francesco_F ,
Consider the following silly code:
   type :: a_t
      integer, allocatable :: x(:)
   end type
   type :: b_t
      type(a_t) :: a(2)
   end type
   type :: c_t
      type(b_t) :: b
   end type
   type(c_t) :: c
   allocate( c%b%a(1)%x(2), source=1 )
   allocate( c%b%a(2)%x(3), source=2 )
   print *, c%b%a(1)%x(1)
   print *, c%b%a(2)%x(2)
end
Upon building and execution, it works as expected:
 1
 2
Press any key to continue . . .
However, if one places a breakpoint at the line 13 during a debugger session in Visual Studio and views the object, the "Undefined pointer/array" info will be noticed:
This has nothing to do with the specific Fortran code, rather it is a gap/limitation of the Intel Fortran integration with Visual Studio.
This is an issue which has long been present in form or other, at least for 10 years or more.  Yet Intel Software team has NOT been able to bring sufficient attention and resources to resolve this problem.
It's beyond shameful.
But there is nothing the customers can do other than use "tricks": one such option - not that I always recommend it - is to use ASSOCIATE construct with temporary code used for debugging.  For example,
Francesco_F
I thank you for the kind and quick reply, you were very helfpful, even if unfortunately the proposed solution can only be a work-around of the problem.
In that case, I would prefer the use of ALLOCATABLE: type(a_t), ALLOCATABLE :: a(:)
   type :: a_t
   end type
   type :: b_t
      type(a_t) :: a(2)
      type(a_t), ALLOCATABLE :: aa(:)   ! => this is fine for VS
   end type
   type :: c_t
      type(b_t) :: b
   end type
   type(c_t) :: c
   allocate( c%b%a(1)%x(2), source=1)
   allocate( c%b%a(2)%x(3), source=2)
   ALLOCATE(c%b%aa(2))
   allocate( c%b%aa(1)%x(2), source=1)
   allocate( c%b%aa(2)%x(3), source=2)
   print *, c%b%a(1)%x(:)
   print *, c%b%a(2)%x(:)
   print *, "--------------------------"
   print *, c%b%aa(1)%x(:)
   print *, c%b%aa(2)%x(:)
end
In this way we don't need to use the ASSOCIATE construct to do debugging (in general I never use prints, this was just to look at the real bahaviour of the code).
FortranFan
You can do whatever works out for you, but know that rejigging one's class definitions (such as with your thought of making a certain component of a type composition derived type with the ALLOCATABLE attribute) in order to function with an outdated and gap-ridden debugger extension in Visual Studio is neither always possible nor advisable, in many circumstances that will be akin to placing the cart before the horse.  Also, there is no guarantee such refactoring will always work with the Intel debugger.  With components of derived type and other objects, with Intel Fortran integration with Visual Studio, "Undefined pointer/array" is a rather common encounter.
But if that's what you prefer, more power to you.
JohnNichols
Valued Contributor III
The same thing happens with parameters, you cannot see them.  I realize they are not variables, but it would be nice to see them in watch otherwise you need to look them up.
Steve_Lionel
PARAMETER constants are visible in the debugger if you select the option /debug-parameters:[none/used/all]
Devorah_H_Intel
@Francesco_F  Over the past years, we have successfully resolved numerous debugger issues.
Currently, we are actively working on fixing a new issue that you have submitted. If you come across any additional debugger issues, we kindly request you to submit them on this forum for our attention and resolution.
jimdempseyatthecove
While I do not have a reproducer handy, on MS VS 2019
block
  real :: somevar
  somevar = expression
  (break on line following, somevar not visible)
end block
IOW variables declared within a block are not visible in the debugger when within the block. Those variables outside the block remain visible as expected.
Jim Dempsey
Devorah_H_Intel
Thank you, @jimdempseyatthecove - for reporting this to us. We are working on the issue.
Devorah_H_Intel
FortranFan
That's great @Devorah_H_Intel .  Please see this comment in another ongoing thread:
https://community.intel.com/t5/Intel-Fortran-Compiler/Intel-oneAPI-segmentation-fault-on-valid-F2018-code/m-p/1505243#M167254
Will it be possible for you to follow-up on that more complicated case where the "undefined pointer/array" issue persists.
