Intel® HPC Toolkit
2089 Discussions
IRECV/SSEND crashes for Intel MPI Library 2019
John_Young
I noticed that one of our MPI codes begin crashing after installing Intel Parallel Studio XE 2019 (Intel MPI Library 2019 Update 1) on Windows.  I tracked down the issue to a combination of SSEND/IRECV when the transferred data reaches a certain size.  Test code exhibiting the crash is attached.  The code does not crash when using Intel Parallel Studio XE 2018 (Intel MPI Library Update 3).
In particular, the 2019 library exhibits a crash when the double precision (square) matrix being transferred has a dimension of around 360-365 in the vicinity of 135K total elements.  The crash occurs for both the 4-byte and 8-byte MPI interfaces.  My compile and dispatch commands are
mpiifort -fpp -DMPI_MPI_INTEGER_TYPE=4 -DMPI_SYS_INTEGER_TYPE=4 test.F90
mpiexec -n 2 ./test.exe
for the 4-byte interface and
mpiifort -ilp64 -i8 -fpp -DMPI_MPI_INTEGER_TYPE=8 -DMPI_SYS_INTEGER_TYPE=8 test.F90
for the 8-byte interface.
Any help or suggested workaround is much appreciated.
John
James_T_Intel
There is a fix for this implemented in Intel® MPI Library 2019 Update 2.  Until this is released, you can run with I_MPI_FABRICS=ofi to work around this issue.
John_Young
Great. Thanks for letting us know.
John
John_Young
I have updated to Intel MPI Library 2019 Update 2 on MS Windows and the bug still occurs.  The originally attached program still crashes at the same place unless I_MPI_FABRICS is set to ofi.
Is there any ETA on when this bug will be fixed?
John
James_T_Intel
We had an unexpected change regarding Update 2, so fixes planned for Update 2 were moved to Update 3.  I apologize for the delays, the fix should be available soon.
