I installed opencl intel fpga sdk 19.2 and after installation the hello world example seems to compile smoothly taking default board as Arria10GX. But when i try giving the emulator compilation, i get following error:
My Machine spec:
Xeon-16 cores,32 GB RAM and Ubuntu 18.04.
aoc -march=emulator -fast-emulator -v device/hello_world.cl -o bin/hello_world.aocx
Warning: Command has been deprecated. The Fast Emulator is the default emulator; use -legacy-emulator if you wish to target the Legacy Emulator.
Error: aoc: The Intel(R) Kernel Builder for OpenCL(TM) compiler (ioc64) can not be found
Any idea on how i can fix this.
Vinay,
Please, check that you set the environment variable CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=<number_of_devices>.
For more information about emulating OpenCL Kernels read here.
Sergey
Hello Intel Folks,
May i request you to please suggest solution for me. I need emulator urgently for my development.
Hello Vinay,
Sorry for delay in answer.
In previous version of aoc you should use "-march=emulator and -fast-emulator".
In 19.2 version, please, use "-march=emulator -legacy-emulator".
I guess, documentation of aoc was not updated to 19.2.
Sergey
Thanks Sergey for your help.
Now i am able to compile, but running gives error as below:
ERROR: CL_DEVICE_NOT_FOUND
Query for number of devices failed
Please let me know how i can get this working.
My Runs are as below :
(base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ aoc -march=emulator -legacy-emulator -board=a10gx device/hello_world.cl -o bin/hello_world.aocx
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Linking Object files....
aoc: Compiling for Emulation ....
------------------------------Make of hello world --------------------------------------------------------------------------------------
(base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ make
../common/src/AOCLUtils/opencl.cpp: In function ‘_cl_program* aocl_utils::createProgramFromBinary(cl_context, const char*, _cl_device_id* const*, unsigned int)’:
../common/src/AOCLUtils/opencl.cpp:388:22: warning: ignoring attributes on template argument ‘cl_int {aka int}’ [-Wignored-attributes]
scoped_array<cl_int> binary_status(num_devices);
------------------------------Running hello world ---------------------------------------------------------------------
(base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ bin/host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
Vinay,
Sergey
Thanks Sergey, it really helped.
Hi Sergey,
I work in Vinay's team. I was trying out the Sobel Filter Design Example. While compiling the host code I got this error
host/src/display.cpp:23:10: fatal error: SDL2/SDL.h: No such file or directory
#include <SDL2/SDL.h>
compilation terminated.
Makefile:74: recipe for target 'bin/host' failed
make: *** [bin/host] Error 1
Please help me to solve this.
Thanks and regards,
Hamsika.
Use this library in ur path.It will work
cheers,
Prithvi (ISRO)
Hi Hamsika,
Sorry for delay.
Could you please check that you have libsdl2-dev on your machine?
If not, you can install it by executing this command:
sudo apt-get install libsdl2-dev
