Intel® High Level Design
710 Discussions
quartus prime ip parameter editor
Ak_3004
'No compatible IP parameter editor found. This may be because the IP is not installed or because the latest editor is no longer compatible with the IP variant file.'
I got this Error when I was trying to convert my code which was initially written for Cyclone III device using Quartus II to MAX 10 device using Quartus Prime Lite version.
It would be really great if someone could guide me on how to resolve this.
ShengN_Intel
Probably the compatible issue. Please create a new one IP in lite version. Quartus II to Lite version probably will have obsolete IP.
Sheng
HubertG
Hi Ak_3004,
Would like to follow up..
May I know, have you tried the workaround provided previously and does it solve your problem ?
Best Regards
Hubert
HubertG
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
