Intel® MPI Library
2228 Discussions
MPI_Put: RDMA_WRITE error which MPI_Accumulate works fine
foxtran
Hello!
I'm trying to use one sided communications for load balancing with MPI.
The algorithm steals some jobs from other MPI threads. For this, it makes MPI_Win_lock, MPI_get, some computing, MPI_put, MPI_Win_unlock. For the rank, which owns memory, it works fine, but call MPI_Put in other ranks leads to
[vn01:3300889:0:3300889] ib_mlx5_log.c:177  Remote access on mlx5_bond_0:1/RoCE (synd 0x13 vend 0x88 hw_synd 0/0)
[vn01:3300889:0:3300889] ib_mlx5_log.c:177  RC QP 0x2f537 wqe[3]: RDMA_WRITE --- [rva 0x7fd2d7be90a8 rkey 0x2e76c7] [inl len 16] [rqpn 0x2f541 dlid=0 sl=0 port=1 src_path_bits=0 dgid=::ffff:10.152.0.10 sgid_index=3 traffic_class=0]
With a nice backtrace:
Image              PC                Routine            Line        Source
libpthread-2.28.s  00007FD0A06EECF0  Unknown               Unknown  Unknown
libc-2.28.so       00007FD09FBD7ACF  gsignal               Unknown  Unknown
libc-2.28.so       00007FD09FBAAEA5  abort                 Unknown  Unknown
libucs.so.0.0.0    00007FD09C6922E6  Unknown               Unknown  Unknown
libucs.so.0.0.0    00007FD09C6974F4  ucs_log_default_h     Unknown  Unknown
libucs.so.0.0.0    00007FD09C697814  ucs_log_dispatch      Unknown  Unknown
libuct_ib.so.0.0.  00007FD09BD314FA  uct_ib_mlx5_compl     Unknown  Unknown
libuct_ib.so.0.0.  00007FD09BD483A0  Unknown               Unknown  Unknown
libuct_ib.so.0.0.  00007FD09BD32F9D  uct_ib_mlx5_check     Unknown  Unknown
libuct_ib.so.0.0.  00007FD09BD463AA  Unknown               Unknown  Unknown
libucp.so.0.0.0    00007FD09CC5282A  ucp_worker_progre     Unknown  Unknown
libucp.so.0.0.0    00007FD09CC6A318  ucp_worker_flush      Unknown  Unknown
libmlx-fi.so       00007FD09CEDD50D  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007FD0A0F5205F  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007FD0A0F64E46  Unknown               Unknown  Unknown
libmpi.so.12.0.0   00007FD0A0F43593  PMPI_Win_unlock       Unknown  Unknown
libmpifort.so.12.  00007FD0AAC4A01D  mpi_win_unlock__      Unknown  Unknown
a.out              0000000000405B9B  Unknown               Unknown  Unknown
a.out              0000000000405DCC  Unknown               Unknown  Unknown
a.out              00000000004052AD  Unknown               Unknown  Unknown
libc-2.28.so       00007FD09FBC3D85  __libc_start_main     Unknown  Unknown
a.out              00000000004051CE  Unknown               Unknown  Unknown
The same code works fine with OpenMPI, and also, replacing of MPI_Put to MPI_Accumulate is also works fine. You can try to uncomment lines 170 and 216 with removing of MPI_Put calls.
In the attachment you will find not minimal, but relatively clear example which leads to failing. It will fail for 2-5 MPI ranks because of task scheduling.
compilation:
mpiifx put.f90 -cpp
running:
mpirun -n 4 ./a.out
Used MPI version 2021.13 and IFX 2024.2.1 (from the latest HPC toolkit)
Igor
taehunkim
This problem is not reproduced in our internal system.
Why don't you refer to the below URL and configure 'I_MPI_PMI_LIBRARY' environment?
https://www.intel.com/content/www/us/en/docs/mpi-library/developer-reference-linux/2021-13/other-environment-variables.html#GUID-6B9D4E5C-8582-42E6-B7DA-72C87622357D
foxtran
Hmm... Are there some ways to get more details about this error on my machine?
taehunkim
Here are some steps to troubleshoot and resolve this issue:
  • Check OFI Providers: Ensure that the necessary OFI providers are installed on your system. You can check the available providers by running:
         $ fi_info
           This command should list the available fabric interfaces. If it returns "No data available," it means no suitable providers are found.
  • Configure Intel MPI to Use a Specific Provider: Sometimes, specifying a particular provider can help. You can set the FI_PROVIDER environment variable to a specific provider that is available on your system.  For example:
            $ export FI_PROVIDER=sockets
         You can add this line to your Slurm job script before the mpirun or srun command.
  • Check Network Configuration: Ensure that the network interfaces on your nodes are properly configured and accessible. The OFI provider might be looking for specific high-performance network interfaces (like InfiniBand or Omni-Path) that are not configured or available.
  • Intel MPI Configuration: Intel MPI can be configured to use different communication fabrics. You can try setting the I_MPI_FABRICS environment variable to use a different fabric. For example:
              $export I_MPI_FABRICS=shm:ofi  or   export I_MPI_FABRICS=shm:tcp
          Add this line to your Slurm job script before the mpirun or srun command.
You can get hint at here ( https://www.intel.com/content/www/us/en/docs/mpi-library/developer-reference-linux/2021-13/ofi-capable-network-fabrics-control.html )
foxtran
Hi!
Shortly, the problem occurs only with `I_MPI_FABRICS=ofi`. Looks like it is a problem with choosing some default provider, when it is not available.
On my machine, I have the following fi providers:
$ fi_info | grep provider | sort -u
provider: mlx
provider: psm3
provider: shm
provider: tcp
provider: tcp;ofi_rxm
provider: verbs
provider: verbs;ofi_rxm
I checked all of them, and all of them works fine
Then, I just set `I_MPI_FABRICS=54543`, and I saw the following message:
MPI startup(): 54543 fabric is unknown or has been removed from the product, please use ofi or shm:ofi instead.
As you can see, I do not have `ofi` (and `shm:ofi`) provider, but MPI suggests to use it.
So, I set `I_MPI_FABRICS=ofi` and then I saw my error with RDMA_Write. At the same time, `I_MPI_FABRICS=shm:ofi` works fine
Igor
TobiasK
@foxtran OFI is not the provider, OFI provides the providers:)
Are you running on an AMD platform?
